Time to move on, Where to start??? |
catsltd |
Aug 28 2015, 07:49 AM
Member Group: Members Posts: 181 Joined: 7-June 15 From: Calgary Alberta Member No.: 18,814 Region Association: None |
Got the car running tip top.
Replaced coil,plugs.injectors,old rubber hoses,etc. Now I am down to my biggest remaining problem:Oil Leaks. When I had the car in to shop getting fucked up,they told me these were the areas that had leaks. Rear Main seal. Oil leaking from head(cylinder seal),I am assuming head gasket. Differential side seals.(Probably NOT RELATED???). The car is running great,but it is loosing a lot of oil through these leaks. Questions: 1.Can I fix these thing without removing the engine???(This is the last thing I want to do). 2. Where do I start. Thanks for any suggestions. Grant. |
bandjoey |
Aug 28 2015, 08:00 AM
bandjoey Group: Members Posts: 4,926 Joined: 26-September 07 From: Bedford Tx Member No.: 8,156 Region Association: Southwest Region |
I would suggest. Get a bottle and sprayer of Simple Green bio degreaser and the garden hose. Spray it down and scrub it off clean. This stuff will fade paint if left on. Drive, take pictures of the leaks. U might just find out the common every car leaks are the pushrods tubes and oil cooler. Both easy to fix in the car. Post the pictures and we'll give u a way to go. (IMG:style_emoticons/default/welcome.png)
catsltd |
Aug 28 2015, 08:25 AM
I would suggest. Get a bottle and sprayer of Simple Green bio degreaser and the garden hose. Spray it down and scrub it off clean. This stuff will fade paint if left on. Drive, take pictures of the leaks. U might just find out the common every car leaks are the pushrods tubes and oil cooler. Both easy to fix in the car. Post the pictures and we'll give u a way to go. (IMG:style_emoticons/default/welcome.png) This sounds like A GREAT IDEA. I will post pictures once I remove all the crude. If I drop the motor I will be done driving for the year,and I am not ready for that yet. So I will see where the pictures take me for now. |
Lo-Fi Version | Time is now: 21st May 2024 - 01:42 AM |
