Time to move on, Where to start??? |
catsltd |
Aug 28 2015, 07:49 AM
Member Group: Members Posts: 181 Joined: 7-June 15 From: Calgary Alberta Member No.: 18,814 Region Association: None |
Got the car running tip top.
Replaced coil,plugs.injectors,old rubber hoses,etc. Now I am down to my biggest remaining problem:Oil Leaks. When I had the car in to shop getting fucked up,they told me these were the areas that had leaks. Rear Main seal. Oil leaking from head(cylinder seal),I am assuming head gasket. Differential side seals.(Probably NOT RELATED???). The car is running great,but it is loosing a lot of oil through these leaks. Questions: 1.Can I fix these thing without removing the engine???(This is the last thing I want to do). 2. Where do I start. Thanks for any suggestions. Grant. |
bdstone914 |
Aug 29 2015, 09:23 AM
bdstone914 Group: Members Posts: 4,523 Joined: 8-November 03 From: Riverside CA Member No.: 1,319 |
Don't forget the push rod seals. When you pull the flywheel look at the oil galley plugs. They have been known to leak or blowout. If they leak the common fix is to add threaded plugs. Must be done carefully to not get metal shaving in the oil passages.
Lo-Fi Version | Time is now: 20th May 2024 - 11:03 PM |
