help!: power to wipers |
jimkelly |
Aug 29 2015, 10:05 AM
Delaware USA Group: Members Posts: 4,969 Joined: 5-August 04 From: Delaware, USA Member No.: 2,460 Region Association: MidAtlantic Region |
will 12v to one of the spades any of these wires went to, make my wipers move? assuming my wiper motor is ok.
wire colors: black/purple black/blue green/white red/black or would I need to run a positive the solid green wire and a negative to the solid black wire just above the other wires in top pics. thanks guys. got horn working : ) pretty cool to have wired my first relay. other pic. Attached thumbnail(s) |
Mike Bellis |
Aug 29 2015, 10:13 AM
It's been a while and I don't have the schematic in front of me... I think you need power on the red/black and then pt power on the green/white.
Red/black will need key switched power. the other wires are fast, slow, park for the system. Also make sure you have a good ground to the motor. |
jimkelly |
Aug 29 2015, 11:51 AM
thanks.
tried that but no luck. tapped red/blk to battery, nothing happened. tapped green/white to battery, small spark. motor might be bad, think I may have to pull it and try it outside of car. any other ideas. Attached thumbnail(s) |
jimkelly |
Aug 29 2015, 12:18 PM
got it.
only black/purple that needs power to make wipers move. got to get better switches. but like 3m heat shrink connections and my tools, wayteck crimper (not perfect but works well when being real careful to center crimp in right location). lighter works well for shrinking. the only thing is that with shrouded connections, you need to be sure you got the spade in the connection and not just pushed into the shroud : ( thanks jim Attached image(s) |
Lo-Fi Version | Time is now: 26th April 2024 - 10:03 PM |
