Webber Carbs, Kits for Webber carbs |
02loftsmoor |
Aug 30 2015, 01:52 PM
Senior Member Group: Members Posts: 577 Joined: 26-June 11 From: Ft. Worth TX Member No.: 13,243 Region Association: Southwest Region |
I know to stay away from Webbercarbsdirect, what vender do you guys use for your rebuild kits and I need linkage parts also..
Wes |
jimkelly |
Aug 30 2015, 01:55 PM
Delaware USA Group: Members Posts: 4,969 Joined: 5-August 04 From: Delaware, USA Member No.: 2,460 Region Association: MidAtlantic Region |
porschetub |
Aug 30 2015, 02:18 PM
Advanced Member Group: Members Posts: 4,699 Joined: 25-July 15 From: New Zealand Member No.: 18,995 Region Association: None |
I know to stay away from Webbercarbsdirect, what vender do you guys use for your rebuild kits and I need linkage parts also.. Wes The secrets out (IMG:style_emoticons/default/biggrin.gif) (IMG:style_emoticons/default/biggrin.gif) ,for the best quality and range of hard parts go to seller alfa1750 on ebay,they are great to deal with and the seller knows Weber,Dellorto and Solex/Zenith,they can also supply rebuilt carbs done inhouse. Ok the parts come from Italy but the shipping is cheap and fast with prices that blow the competition out of the water,I'am happy to recommend as over 6 transactions with them it has been 100%. |
URY914 |
Aug 30 2015, 02:20 PM
I built the lightest 914 in the history of mankind. Group: Members Posts: 120,662 Joined: 3-February 03 From: Jacksonville, FL Member No.: 222 Region Association: None |
CBperformance will screw you on shipping costs.
Try these out too: http://vwparts.aircooled.net/default.asp http://www.piercemanifolds.com/default.asp http://www.carburetion.com/index.htm |
porschetub |
Aug 30 2015, 02:22 PM
yes Jim they have a fair range but I found shipping was very expensive,no sure if anyone else has noted that? |
02loftsmoor |
Aug 30 2015, 02:34 PM
great tips guys' I book marked the web sites.
Thank you Wes |
jimkelly |
Aug 30 2015, 02:56 PM
I called them about shipping charges. seem you have to look for the box to change shipping from their preset method to others. did not realize others had the same issue I had.
here is the important selection location, which I missed many times. Attached thumbnail(s) |
02loftsmoor |
Aug 30 2015, 03:00 PM
Good to know and watch for. thank you Jim
Ian Stott |
Aug 30 2015, 03:10 PM
Senior Member Group: Members Posts: 907 Joined: 28-January 08 From: Moncton/Canada Member No.: 8,635 Region Association: Canada |
What is the preferred carb setup for the 2056?
Ian Stott Moncton Canada |
Lo-Fi Version | Time is now: 18th May 2024 - 11:29 AM |
