Headlight Won't Go Down, Seeking Advice |
andys |
Sep 6 2015, 05:18 PM
Advanced Member Group: Members Posts: 2,165 Joined: 21-May 03 From: Valencia, CA Member No.: 721 Region Association: None |
The driver side headlight on my '75 914 won't go down when the switch is turned off. I tried probing around and found I can get it to go down by lightly pushing on the black sleeving that covers the green wire. I thought, ok, must be a broken wire, or a broken solder joint. I cut away the sleeving and I see what looks to be a capacitor (?).
I the accompanying photo, if I push on the capacitor lead adjacent to the motor terminal, I get nothing. If I push on the capacitor lead at the green wire, I get nothing. However, if I push on the capacitor lead close to its (black) body at the one o'clock side, the light goes down. I get nothing pushing on the seven o'clock side. Damaged capacitor perhaps? I have a set of motors from a '72 or '73 (don't know if they work), but will I find the same capacitor under their sleeving? Would I be better off buying a new capacitor from the electronics supply? Does anyone know the value of the capacitor? Thanks, Andys Attached thumbnail(s) |
andys |
Sep 7 2015, 12:22 PM
Era Vulgaris,
That's as good a photo as I could take, as the diode is kind of a ways down in a hole. Yeah, wish I could read the numbers. Marty, I'd be great if your factory manual has the info on it. You're right, maybe a shout out to Jeff Blowsby. It's just such a hassle to remove the motor just to read the numbers, I'd prefer someone with the magic answer. Andys |
Lo-Fi Version | Time is now: 26th May 2024 - 03:16 PM |
