| EdwardBlume |
Sep 10 2015, 10:44 AM
914 Wizard ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() Group: Members Posts: 12,339 Joined: 2-January 03 From: SLO Member No.: 81 Region Association: Central California
I have a spongy brake pedal that firms up upon pumping. No visible leaks, I think the brakes just need bleeding.
Any good how to descriptions, especially how I can do it by myself? What equipment is needed to fill fluid? Thanks, Rob |
| Martin Baker |
Sep 10 2015, 12:25 PM
I just heard I sold my cars! ![]() ![]() ![]() Group: Members Posts: 1,140 Joined: 11-February 03 Member No.: 290 Region Association: Northern California
Here is the method I use, to bleed brakes alone, or with friends. Caliper up, force the air the way it wants to travel. They are a bit pricey, but worth it. It saves time as well.
http://www.brakebleeder.com/product-category/brake-bleeders/ |
| aircooledtechguy |
Sep 10 2015, 12:29 PM
The Aircooledtech Guy ![]() ![]() ![]() Group: Members Posts: 1,966 Joined: 8-November 08 From: Anacortes, WA Member No.: 9,730 Region Association: Pacific Northwest |
A great little tool that is normally available at FLAP is this kit by Lisle:
http://www.amazon.com/Lisle-19200-Brake-Bl...t/dp/B0009OMY9M Keeps you from making a mess and allows you to bleed by yourself. You can use this in conjunction with a set of speed bleeders (one at each brake): http://www.pelicanparts.com/cgi-bin/ksearc....x=0&I1.y=0 For client cars, I use the Lisle one man bleeder in conjunction with a power bleeder and it makes quick work of bleeding but that may be a bit much for occasional use: http://www.pelicanparts.com/cgi-bin/ksearc...rchButtonGo.y=0 |
| Bartlett 914 |
Sep 10 2015, 12:42 PM
Advanced Member ![]() ![]() ![]() ![]() Group: Members Posts: 2,218 Joined: 30-August 05 From: South Elgin IL Member No.: 4,707 Region Association: Upper MidWest |
When I bleed brakes, I place the plastic tube moving vertical for some distance. It makes it easier to see bubbles. The brake fluid in the tube helps prevent air from going back into the system. I usually have help but I think this may work solo.
| andrewb |
Sep 10 2015, 12:47 PM
Member ![]() ![]() Group: Members Posts: 114 Joined: 25-May 10 From: UK Member No.: 11,762 Region Association: None |
I use a jack handle or a piece of wood and a piece of clear hose. No expensive kit, no assistant. (Probably no friends either (IMG:style_emoticons/default/sad.gif) )
1. Get a piece of wood (say 2" x 2") about 18" long (or a jack handle) and position the drivers seat so that the distance from the brake pedal to the front of the seat base is slightly less than the length of the piece of wood. 2. Now slide the seat forward another couple of clicks so that when you wedge the wood between the seat base and the pedal it applies pressure to the pedal. Don't put the wood in place just yet. 3. Starting with the caliper furthest from the master cylinder, assuming you're doing all 4, undo the bleed nipple and make sure it turns freely - then nip it up gently. Put a ring spanner on the nipple and then the clear hose onto the nipple with the other end into a container. 4. Put one end of the piece of wood on the brake pedal and push it until the other end is wedged against the front of the seat. 5. Open the bleed nipple a fraction - it will spit some air out and maybe a bit of fluid. Quickly nip the nipple back up. 6. The piece of wood will no longer be tightly wedged because you've released the pressure that was holding the pedal up. Remove the wood, allowing the pedal to come back up, and then wedge the wood back in place as before. Repeat stage 5. Each time more fluid and less air bubbles will appear in the clear hose. Once you have clear fluid and no bubbles give it 2 or 3 more cycles to be sure and then you're done. Tighten the nipple properly and then do the other 3 in order of decreasing distance from the master cylinder. Don't forget to keep topping up the reservoir. I've been doing it this way for over 30 years starting with a '67 Beetle and I'm still doing it on newish cars with ABS. Works every time. Andrew |
| JeffBowlsby |
Sep 10 2015, 12:59 PM
914 Wiring Harnesses & Beekeeper ![]() ![]() ![]() ![]() ![]() Group: Members Posts: 9,111 Joined: 7-January 03 From: San Ramon CA Member No.: 104 Region Association: None
Speedbleeders, a length of clear tubing and a container for the effluent. That's all that's needed.
| Elliot Cannon |
Sep 10 2015, 01:57 PM
914 Guru ![]() ![]() ![]() ![]() ![]() Group: Retired Members Posts: 8,487 Joined: 29-December 06 From: Paso Robles Ca. (Central coast) Member No.: 7,407 Region Association: None
| dlee6204 |
Sep 10 2015, 02:11 PM
Howdy ![]() ![]() ![]() ![]() Group: Members Posts: 2,162 Joined: 30-April 06 From: Burnsville, NC Member No.: 5,956 |
Nothing special. I run clear tubing from the caliper directly to the master cylinder and just keep pumping.
| kupcar |
Sep 10 2015, 03:53 PM
Member ![]() ![]() Group: Members Posts: 95 Joined: 14-February 13 From: Chicago Member No.: 15,528 Region Association: None |
I've used a Mighty Vac pressure bleeder for years. It's simple and cheap. I think under $30.
| Jeffs9146 |
Sep 10 2015, 03:59 PM
Ski Bum ![]() ![]() ![]() ![]() Group: Members Posts: 4,062 Joined: 10-January 03 From: Discovery Bay, Ca Member No.: 128 |
I have used this for 20+ years!
| Cairo94507 |
Sep 10 2015, 04:17 PM
Michael ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() Group: Members Posts: 10,490 Joined: 1-November 08 From: Auburn, CA Member No.: 9,712 Region Association: Northern California
Hey Rob - If all you need is a body for assistance I can come over and lend a foot.
Michael |
| EdwardBlume |
Sep 10 2015, 04:43 PM
| EdwardBlume |
Sep 10 2015, 04:44 PM
Thanks for all the input guys! I'll see what I have and give it a go.
| Kansas 914 |
Sep 10 2015, 05:02 PM
Advanced Member ![]() ![]() ![]() ![]() Group: Members Posts: 3,006 Joined: 1-March 03 From: Durango, Colorado Member No.: 373 Region Association: Rocky Mountains
Nothing special. I run clear tubing from the caliper directly to the master cylinder and just keep pumping. I use a version of this but have four long lines. One from each caliper back to the fluid reservoir and pump until I have moved all new fluid to the calipers. Just eliminating bubbles helps but one should move at least 8 ounces through each caliper, or so I was told by a wise man. |
| EdwardBlume |
Sep 10 2015, 05:19 PM
How much brake fluid should I buy then? and what type of brake fluid is ideal? does it matter?
| r_towle |
Sep 10 2015, 06:55 PM
Custom Member ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() Group: Members Posts: 24,705 Joined: 9-January 03 From: Taxachusetts Member No.: 124 Region Association: North East States
How much brake fluid should I buy then? and what type of brake fluid is ideal? does it matter? If you have never changed your brake fluid, it may be in your best interest to do it. Couple of quarts will do it. DOT4 Add red food coloring dye. Pump till it comes out red on all four corners. Start with the passenger rear, then drivers rear, then passenger front, then drivers front. Next year use clear fluid, or use blue food coloring dye. Speed bleeders and a hose into a bottle will save you relationship issues. A pressure bleeder like Jeff posted will make the whole project a dream. Rich |
| smj |
Sep 10 2015, 09:44 PM
"Dude, Steve from Berkeley." ![]() ![]() ![]() Group: Members Posts: 591 Joined: 28-August 05 From: Berkeley, CA Member No.: 4,691 Region Association: Northern California
I've used the Motive pressure bleeders for years. You can probably get a firmer pedal with good execution of the two person methods, but it was good enough when I was doing 20+ DE days in a season and lacked a helper..
With that setup, a liter was generally enough to flush a 944S - might need less with the 914. It was certainly enough for my /4 the other day. And I would alternate between Ate Super Blue and Ate Gold (Typ 200) fluid for the kind of easy visual check Rich mentioned, but I think I heard/read somewhere that only gold/yellow fluid was legal now in the States... (Ah, in 2013 according to Hooniverse - though I see links for it from US retailers via Google Search) I've still got the original 17mm master cylinder in the /4, and I'd describe the performance as: Meh. If bleeding doesn't help, check the MC and lines - and you probably already know that upgrading to the 19mm MC is very popular... |
| yeahmag |
Sep 10 2015, 10:10 PM
Advanced Member ![]() ![]() ![]() ![]() Group: Members Posts: 2,468 Joined: 18-April 05 From: Pasadena, CA Member No.: 3,946 Region Association: Southern California
Love my Motiv...
| infraredcalvin |
Sep 10 2015, 10:13 PM
Distracted Member ![]() ![]() ![]() Group: Members Posts: 1,697 Joined: 25-August 08 From: Ladera Ranch, CA Member No.: 9,463 Region Association: Southern California
Do not route old fluid back into resovoir, it defeats the purpose. Submerge the end of the hose in some fluid, that way when all the bubbles are out and the pedal is released it sucks back fluid vs air.
Start with furthest caliper from the MC and work your way back to closest. Donot let the resovoir go empty and suck air. If you've never done it before enlist a helper and expect to go through it a few times. I've always had great luck with the motive bleeder mentioned by Jeff, well worth the $50. |
| mgp4591 |
Sep 10 2015, 11:29 PM
914 Guru ![]() ![]() ![]() ![]() ![]() Group: Members Posts: 5,806 Joined: 1-August 12 From: Salt Lake City Ut Member No.: 14,748 Region Association: Intermountain Region
If you don't find any air, you may have a binding pad or sticking caliper piston- it feels the same as air and reacts about the same with less that ideal braking, maybe even pulling to the opposite side as the offending unit. Good luck- reading through the other comments you should be able to fix your problem.
Lo-Fi Version | Time is now: 9th November 2025 - 08:21 PM |
