Separating headlight motor from body, How to get this apart? |
boxsterfan |
Sep 12 2015, 10:01 PM
914's are kewl Group: Members Posts: 1,776 Joined: 6-June 03 From: San Ramon, CA Member No.: 791 Region Association: Northern California |
How do these pieces come apart? I can't seem to get the lever off which will then allow me to take the headlight motor out.
Attached thumbnail(s) |
stevegm |
Sep 12 2015, 10:11 PM
Advanced Member Group: Members Posts: 2,111 Joined: 14-July 14 From: North Carolina Member No.: 17,633 Region Association: South East States |
Once the nut is off (as it is in this picture) you can just pry the arm off with a screw driver behind it. It is normally tight. But, it will come off. Then you can take the motor out.
rhodyguy |
Sep 13 2015, 09:00 AM
Chimp Sanctuary NW. Check it out. Group: Members Posts: 22,075 Joined: 2-March 03 From: Orion's Bell. The BELL! Member No.: 378 Region Association: Galt's Gulch |
Index the position the arm should be in.
porschetub |
Sep 13 2015, 12:44 PM
Lo-Fi Version | Time is now: 8th May 2024 - 04:17 PM |
