which cylinders shall i use?, pick one.... |
nebreitling |
Mar 4 2005, 07:14 PM
hi guys
need advice as to which cylinders to run on the 2056... yeah, i know, nickies. but here are the two choices: on the left, a "standard" new 96. on the right, an "unknown" (german??) 94. i got 4 of each, just don't know whether to run the new ones or bore the older (actually very low mileage) ones... you'll note more casting marks on the left one, as well as thicker cooling fins. (IMG:http://www.914world.com/bbs2/html/emoticons/beerchug.gif) Attached image(s) |
nebreitling |
Mar 4 2005, 07:15 PM
asdf
nebreitling |
Mar 4 2005, 07:16 PM
asdf
SLITS |
Mar 4 2005, 07:29 PM
First, you go to a machine shop that can use a dial bore guage and have the 96s checked for ovality and bore size. If they flunk, bore out the 94s.
This assumes you have 96 mm pistons already. End of story PS.....take the pistons with you so that they can measure them to reference the bore. truly, the end of the story. |
Tom Perso |
Mar 4 2005, 09:06 PM
Crazy from the Cold... Group: Members Posts: 647 Joined: 8-August 03 From: Kalamazoo, MI Member No.: 1,003 |
I'd go with the bored 94's. They've already been heat cycled and "aged".
They'll stick within tolerances better. Plus, the quality is better. later, Tom |
Lo-Fi Version | Time is now: 8th May 2024 - 01:37 PM |
