FS: Bilstein OR Boge Struts Package |
a914guy |
Sep 17 2015, 02:36 PM
914 Master Group: Members Posts: 95 Joined: 25-December 02 From: Allen, Texas Member No.: 11 |
You pick: Bilstein or Boge strut package.....
These strut Sets are full serviced, refinished and ready to install. All of my strut sets are checked for straightness in a factory jig so you can count on a perfect fit and correct alignment. You pick either the matched pair of Bilstein struts (91134104230 and 91134104130) or the Boge struts (91134104204 and 91134104104). The Bilstein insert set has been fully serviced at Bilstein (0115001H002) and include new bump stops. If you choose the Boge struts, the matched Koni inserts are very nice low mile adjustable Sport series. Spindle bearing surfaces (inner and outer) are inspected cleaned and checked for proper fit. This package includes the Boxster caliper set perfect for cars with OE wheels (15" or larger) and will work well with unboosted brake systems and even better with power brake cars. Mintex semi-metallic pads included. Hubs are cleaned, media blasted and refinished in VHT clear to seal them and protect the aluminum. Each hub stud is inspected, chased and checked with lugs. New races are installed and new bearing sets and inner seals included. Zimmermann Sport rotors are mounted with new hardware to make this hub set 100%. $2,750.00 plus freight. Strut trades considered. |
euro911 |
Sep 17 2015, 02:56 PM
They both look delicious (IMG:style_emoticons/default/wub.gif)
Lo-Fi Version | Time is now: 11th May 2024 - 02:13 AM |
