DOT 4, 5.1, or 5, New brakes in race car. |
motorvated |
Sep 20 2015, 08:41 PM
Member Group: Members Posts: 279 Joined: 13-February 13 From: Colorado Member No.: 15,519 Region Association: Rocky Mountains |
Just upgraded to 911 suspension and brakes and ready to fill with brake fluid. Car will be raced first with 1.8 L four, then 215 c.i. Aluminum V-8. Since the system is almost all empty of fluid, now is the time to consider switching to DOT 5 silicone based brake fluid. Any suggestions or recommendations.
Thanks, Mike S. |
brant |
Sep 20 2015, 09:52 PM
914 Wizard Group: Members Posts: 11,615 Joined: 30-December 02 From: Colorado Member No.: 47 Region Association: Rocky Mountains |
Dot 4
ThePaintedMan |
Sep 21 2015, 08:12 AM
Advanced Member Group: Members Posts: 3,885 Joined: 6-September 11 From: St. Petersburg, FL Member No.: 13,527 Region Association: South East States |
(IMG:style_emoticons/default/agree.gif) No silicone brake fluid in any kind of track car. I have been using ATE Super Blue, which has a decent boiling point at a good price. As I add more power, I expect to move up to something with an even higher BP, like Wilwood or AP Racing. As a habit I also change fluid before any kind of track outing - the longer it's in the car, the more water it picks up, dropping the BP. That's why there is a "wet" and "dry" BP listed.
NeunEinVier |
Dec 29 2015, 04:25 PM
Member Group: Members Posts: 110 Joined: 24-December 15 From: In front of the smoke. Member No.: 19,488 Region Association: None |
For DOT 4, consider Motul RBF 600, dry boiling point 594F (312C), wet boiling point 401F (205C). Or RBF 660, dry boiling point 617F (325C), wet boiling point 400F (204C).
campbellcj |
Dec 30 2015, 11:10 AM
I can't Re Member Group: Members Posts: 4,542 Joined: 26-December 02 From: Agoura, CA Member No.: 21 Region Association: Southern California |
I can't speak to the merits of the others, but I've also been fine with high-end DOT 4. Endless and Motul most recently.
Cracker |
Dec 30 2015, 01:07 PM
Advanced Member Group: Members Posts: 2,148 Joined: 2-February 10 From: Atlanta (area) Member No.: 11,316 Region Association: South East States |
I run SRF in both of my race cars...never a problem. Dot 4
Tony |
brant |
Dec 30 2015, 11:20 PM
You will need high end like the motul with the v8
But not the 1.8 Start with fresh and clean calipers and cheap fluid. If bleeding an open system (rebuilt calipers/ lines) go through a quart of something cheap to get the air/bleeding done The stock valve or even after market adjustables are hard to bleed without patience or bench bleeding, hammers, trips around the block, or a pressure bleed. You'll go through a lot of fluid Then full flush to something like ate You won't over heat good stock brakes with race pads at your hp and weight You will with the v8/track experience Not while your getting addict... I mean started. Run good pads like the kfp's. you can get brake fade from over heating pads also. Remember a small bore racing 914 is all about momentum. The fastest ones don't use their brakes too often. |
Cracker |
Dec 31 2015, 07:45 AM
Something else to consider. If I were you, I'd just put off the shelf dot4 fluid to start. If you haven't tracked a 914 before...you'll be taking it easy. If you have, you'll be trying to get your head around how to drive it properly. There is plenty of time for you to grow into your car within a performance setting and testing your braking system too. I pay about $75 per liter for my fluid - just an idea. Start cheap, verify systems are all go, have fun learning the car (I doubt you'll be driving 10/10th's), and then upgrade once the car and driver are on the same page. All the best!
PS: Can you clarify what you mean by race? Track day, NASA, HSR, SCCA???? It looks like a hot rod in your avatar... Tony |
Lo-Fi Version | Time is now: 29th April 2024 - 11:38 AM |
