14 Pages V « < 5 6 7 8 9 > »
> jim kelly's 1975 914 suby build, water pump housing and header interference ???
914forme
post Apr 20 2017, 09:04 AM
Post #121
VW coil pack, wow your picture threw me for a minute, but yes that is a VW 2.0L engine out of a golf or jetta, based on the pwoersteering fluid resivor, I would say 1999 - 2001 time frame.
As far as the plug wires, It is a standard on the one end and the other. Most V8 plug wires should work (IMG:style_emoticons/default/confused24.gif) you can get them nice custom ones that you make up, or just go wit a generic set that gets you where your going.
MSD stuff just for example, the price made me dizzy
jimkelly
post Apr 20 2017, 10:32 AM
Post #122
Delaware USA
the vw coil is different than most as it has a pin in the center, see pic. and pic of vw coil mounted on my suby intake manifold.
i'm thinking about these audi wires from ebay: Set of 6 Pcs Spark Plug Ignition Wire Lead For 2.8L VW Passat Audi A4 A6 Quattro
jimkelly
post Apr 20 2017, 05:11 PM
Post #123
Delaware USA
ok, as usual, i am confused. i just installed 36-2-2-2 crank wheel after making the belt at all 3 timing marks. i removed idlers and belt. removed old sprocket and installed new sprocket, lined up the belts 3 marks with the marks on the 2 pulleys and the new sprocket, but after all buttoned up, i noticed that when the cams are lined up and paint marker marks are lined up too, the sprocket mark lines up with my paint marker line, but i about 1 inch counter clockwise of its timing mark.
the odd thing is if i reinstall belt with cam pulleys and sprocket aligned with their timing marks, i expect my paint marker lines won't. i just checked an image of a new 36-2-2-2 sprocket and my old sprocket and they both have their timing mark 180 degrees from the keyway.
guess i'll never know how my paint mark is off (IMG:style_emoticons/default/idea.gif)
914forme
post Apr 20 2017, 06:31 PM
Post #124
Might be a tad short, don't know, I forgot about the pin / never paid attention to it. I only had one car with that igniter, it was a 1999 very early production Jetta. Thing had more electrical issues than all the Lucas cars combined. It was possessed, so I gladly push it out of my memory banks ever chance I get. Everything else I own VW either uses Coil on plug, or does not use spark plugs at all.
I honestly prefer the latter, love my TDIs, and will be getting another one very soon.
914forme
post Apr 20 2017, 06:35 PM
Post #125
Chris H mentioned the same issue in his build thread I think it was Chris. Getting older (IMG:style_emoticons/default/dry.gif) but I recall he ir someone resembling him in my mind had this issue when they did their timing belt. Reason it sticks out in my mind is that I figured I would have fallen for the same Subaru magic trick. Seems odd and that is how Subaru will do the trick, I could be completely off base here also, what the F do I really know (IMG:style_emoticons/default/confused24.gif)
jimkelly
post Apr 20 2017, 06:51 PM
Post #126
Delaware USA
i just turned 53 yesterday. few on this planet can talk to me about old age (IMG:style_emoticons/default/slits.gif)
jimkelly
post Apr 24 2017, 05:15 PM
Post #127
Delaware USA
reinstalled timing belt and think i got it pretty close this time.
also cut off the top of the alternator bracket so i can swing alt to drivers side, so i can install intake facing rear.
tomorrow night i will do some tapping for clt and iat sensors.
got to make a bracket for alternator adjustment. might use some threaded rod ends.
914forme
post Apr 24 2017, 06:10 PM
Post #128
That is looking good
post Apr 24 2017, 07:12 PM
Post #129
Jim, is your engine a "0" clearance style? You might want to remove the plugs to spin the motor by hand. You want to be sure a valve doesn't embed itself in the top of a piston once started. (IMG:style_emoticons/default/beerchug.gif)
Chris914n6
post Apr 24 2017, 07:56 PM
Post #130
Jackstands are my life.
QUOTE(jimkelly @ Apr 20 2017, 04:11 PM) *
On a Nissan that means the belt is backwards. The mark is off 3 teeth or so on one side for some Japanese logic reason (IMG:style_emoticons/default/confused24.gif)
Also, a new belt will have the marks on it if you don't feel 100% with yours.
jimkelly
post Apr 25 2017, 05:43 AM
Post #131
Delaware USA
i made the marks on my belt MYSELF and could have certainly installed back on flipped?
the earlier ej22 are NON interference and is one of the reasons i like them.
http://www.scoobyenthusiast.com/subaru-faq...n-interference/
waiting on a U bend of 1.75" so i can merge my exhaust and put a bung in place for the o2 sensor.
getting the belt right was a little tricky, had to make sure all lined up and all the slack in the belt was in the area of the tensioner.
got to make an alternator adjuster like this. from this thread.
https://www.thesamba.com/vw/forum/viewtopic.php?p=5365250
question, does threaded part between two tie rods have a right hand thread on one side and a left hand thread on the other?
jimkelly
post Apr 25 2017, 05:40 PM
Post #132
Delaware USA
alternator bracket version 1 done. may interfere with timing covers?
now i gotta find a 5 rib belt to turn it.
was gonna install my intake manifold flipped but had one metal fuel line IN THE WAY.
will need to cut the line and put some inches of rubber line.
next up is to merge exhaust for 02 bung.
down the road is shift linkage.
https://www.youtube.com/watch?v=KOgNXNUn8zI
jimkelly
post Apr 26 2017, 02:11 PM
Post #133
Delaware USA
got to fab a run stand exhaust that is 2 into one. did some test cuts on pcv to figure what would be involved.
Chris914n6
post Apr 26 2017, 04:27 PM
Post #134
Belts are measured in mm. Use a "cloth tape" to measure max and min for the alt adjustment as the belt will be in 5mm or 10mm increments. 5K### or ###K5
jimkelly
post Apr 26 2017, 06:12 PM
Post #135
Delaware USA
thanks, good info that i did not know.
got test stand exhaust mostly completely tacked up. gonna ask pro welder to finish it up.
got to add a bit more tail pipe and put a bung in it somewhere.
decided to go ahead and weld it up and let pro welder fix my blow thrus/etc (IMG:style_emoticons/default/smile.gif) and yes that is TIG but most could never tell (IMG:style_emoticons/default/sad.gif)
jimkelly
post Apr 27 2017, 03:57 PM
Post #136
Delaware USA
popped the trans open and will make the conversion coupler.
like these fellas done did.
http://www.914world.com/bbs2/index.php?showtopic=104513
https://www.youtube.com/watch?v=qmPTNe0D-Uc
post Apr 27 2017, 04:24 PM
Post #137
QUOTE(jimkelly @ Apr 26 2017, 05:12 PM) *
Looks OK, Jim. I doubt it will blow loose on those welds. No one can say that you didn't get it hot enough. You can fill that with water to test before installing. Keep 'em coming. You'll be there in no time. (IMG:style_emoticons/default/beerchug.gif)
jimkelly
post Apr 27 2017, 05:04 PM
Post #138
Delaware USA
waiting on a 1' piece of 1.75 od exhaust tubing to add to the end and add the bung.
jimkelly
post May 2 2017, 07:26 AM
Post #139
Delaware USA
my coupler, 2" tall about. hope it holds together.
jimkelly
post May 2 2017, 08:25 AM
Post #140
Delaware USA
side pic
if anyone is going ther bremar coupling route and have these parts left over, i'll take them (IMG:style_emoticons/default/smile.gif)
- Lo-Fi Version Time is now: 25th September 2026 - 12:34 PM
