| jimkelly |
Apr 12 2016, 04:11 PM
Delaware USA ![]() ![]() ![]() ![]() Group: Members Posts: 4,969 Joined: 5-August 04 From: Delaware, USA Member No.: 2,460 Region Association: MidAtlantic Region |
thank you andy (IMG:style_emoticons/default/biggrin.gif)
at a gas station on the way back from picking up engine, a guy asked me what kind of engine is that, i asked, the one in the trunk or the one in the car (IMG:style_emoticons/default/av-943.gif) and another guy told me about ferdinand porsche having a flat 8 cylinder car. harness and ecu OUT (IMG:style_emoticons/default/smile.gif) with only two small cuts to body, one one to finger and one to wrist (IMG:style_emoticons/default/rolleyes.gif) and my hopefully to be driver 1990 subaru legacy auto awd white wire harness question thread.. http://www.914world.com/bbs2/index.php?showtopic=282396 thinking about driving the white one for a while but it has TRANS BINDING which means it probably needs a new DUTY C SOLENOID, thus i am pulling the exhaust and drive shaft, so i can pull rear housing off auto awd trans, so i can get to solenoid a clutch pack. see thread about this... http://forums.nasioc.com/forums/showthread...ghlight=binding Attached thumbnail(s) Attached image(s)
| jimkelly |
May 29 2016, 10:27 AM
great thread on repairing shielded suby wires.
http://bbs.legacycentral.org/viewtopic.php...8&start=425 and another http://personal.press.psu.edu/res122/cars/...ack/WireRepair/ and another http://forums.nasioc.com/forums/showthread.php?t=2474560 pins thread http://www.shoptalkforums.com/viewtopic.ph...53&start=60 http://www.corsa-technic.com/search.php (SEACRH MT OR HW) http://forums.nasioc.com/forums/showthread.php?t=2474560 and http://www.easternbeaver.com/Main/Elec__Pr.../SMHW/smhw.html flatback bug http://www.thesamba.com/vw/forum/viewtopic.php?p=6147650 numbchux http://www.numbchuxconversions.com/home.htm Attached thumbnail(s) Attached image(s)
| jimkelly |
Jun 10 2016, 06:07 PM
pulled engine and trans last night. made a cradle for running engine out of car today. this engine has one cylinder with very low compression but will be fine for testing STOCK ecu and wiring for FI. i removed hoist and am keeping trans and wood blocks in place with a ratchet strap, for now. 2.5 hrs of fabricating/welding and $10 harbour freight furniture dolly.
Attached thumbnail(s) |
| 76-914 |
Jun 10 2016, 06:24 PM
Repeat Offender & Resident Subaru Antagonist ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() Group: Members Posts: 13,968 Joined: 23-January 09 From: Temecula, CA Member No.: 9,964 Region Association: Southern California
The Fun begins Jim. (IMG:style_emoticons/default/popcorn[1].gif) You may need a few aspirin after you cut down that harness. (IMG:style_emoticons/default/blink.gif)
| arkitect |
Jun 10 2016, 10:37 PM
Senior Member ![]() ![]() ![]() Group: Members Posts: 617 Joined: 3-March 10 From: Stockton, CA Member No.: 11,426 Region Association: None |
got me second ej22 today $100. Cool use of your teener to pick up the subaru engine....... (IMG:style_emoticons/default/biggrin.gif) Dave |
| jimkelly |
Jun 11 2016, 03:16 PM
thanks (IMG:style_emoticons/default/smile.gif)
| jimkelly |
Jun 11 2016, 03:19 PM
I have several wires to fix on my harness. somehow I cut several grey sheathed wires. I also need to verify what the diode looks like and find out if it is on my harness. just ordered some suby pins male/female from http://www.corsa-technic.com/category.php?category_id=105
need to weld up a metal trans cradle for my stand and a way to mount radiator. then set up something to hold battery and fuel pump and a small gas tank. jim The Fun begins Jim. (IMG:style_emoticons/default/popcorn[1].gif) You may need a few aspirin after you cut down that harness. (IMG:style_emoticons/default/blink.gif) |
| mepstein |
Jun 11 2016, 03:43 PM
914-6 GT in waiting ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() Group: Members Posts: 20,919 Joined: 19-September 09 From: Landenberg, PA/Wilmington, DE Member No.: 10,825 Region Association: MidAtlantic Region
I have several wires to fix on my harness. somehow I cut several grey sheathed wires. I also need to verify what the diode looks like and find out if it is on my harness. just ordered some suby pins male/female from http://www.corsa-technic.com/category.php?category_id=105 need to weld up a metal trans cradle for my stand and a way to mount radiator. then set up something to hold battery and fuel pump and a small gas tank. jim The Fun begins Jim. (IMG:style_emoticons/default/popcorn[1].gif) You may need a few aspirin after you cut down that harness. (IMG:style_emoticons/default/blink.gif) Jim - you're way more ambitious than me. I sent my harness out for mods. I hope to see it back in a couple weeks - a couple pounds lighter. |
| jimkelly |
Jun 11 2016, 04:35 PM
ambitious, no. (IMG:style_emoticons/default/poke.gif) poking myself (IMG:style_emoticons/default/biggrin.gif)
frugal and on a tight budget, yes. (IMG:style_emoticons/default/hissyfit.gif) |
| 76-914 |
Jun 12 2016, 03:24 PM
ambitious, no. (IMG:style_emoticons/default/poke.gif) poking myself (IMG:style_emoticons/default/biggrin.gif) frugal and on a tight budget, yes. (IMG:style_emoticons/default/hissyfit.gif) Don't shy away from saving $$$ Jim. $750 is nothing to sneeze at. You can also build your own cradle and save enough to buy a nice used Miller Mig w/ tank, a pipe bender and a tube notcher. Weld up your own shift mechanism and save ~$200. (IMG:style_emoticons/default/beerchug.gif) |
| mepstein |
Jun 12 2016, 05:46 PM
ambitious, no. (IMG:style_emoticons/default/poke.gif) poking myself (IMG:style_emoticons/default/biggrin.gif) frugal and on a tight budget, yes. (IMG:style_emoticons/default/hissyfit.gif) Don't shy away from saving $$$ Jim. $750 is nothing to sneeze at. You can also build your own cradle and save enough to buy a nice used Miller Mig w/ tank, a pipe bender and a tube notcher. Weld up your own shift mechanism and save ~$200. (IMG:style_emoticons/default/beerchug.gif) My guy is charging me $550 but for me, it's money well spent. A major electrical event in my house was changing out the bathroom fan for an identical unit. |
| rightpedal |
Jun 12 2016, 07:00 PM
rightpeda; ![]() ![]() Group: Members Posts: 60 Joined: 6-September 15 From: annapolis Member No.: 19,133 Region Association: MidAtlantic Region |
I might be able to help with the cradle. Want to shoot for next weekend on the v8 car?
| jimkelly |
Jun 12 2016, 07:21 PM
I already have the suby cradle and trans hangers from coldwater and it is very nicely designed and made. glad to have it.
sunday for v8 car sounds good, got to check with wife but it think sunday is clear, I will place my summit order for gaskets/etc tomorrow. thanks jim ps: i've been posting some misc suby pics here so i can share them with suby guys on other threads asking for help with my auto trans binding issue. I might be able to help with the cradle. Want to shoot for next weekend on the v8 car? Attached thumbnail(s) |
| jimkelly |
Jun 27 2016, 05:58 AM
i bit off topic but i am making my recently bought 1990 legacy with ej22 my daily driver for a while. it needs structs and springs. i want to lower it. i the meanwhile i have an ej22 on a stand and am getting ready to get it running our of car.
this is how: http://bbs.legacycentral.org/viewtopic.php?f=6&t=51784 Attached thumbnail(s) Attached image(s)
| jimkelly |
Jul 1 2016, 09:10 PM
engine stand getting closer to finished and closer to letting me start on wiring FI. engine and radiator and trans are now all part of the stand (IMG:style_emoticons/default/smile.gif)
engine plugs f25 and f26 schematics for 3 engine plug type ej22. Attached thumbnail(s) Attached image(s)
| jimkelly |
Jul 13 2016, 04:51 PM
latest of engine on stand... amnd video of harness i need to button up.
and my steel can gas tank with fuel pump mounted to lid. https://www.youtube.com/watch?v=6bgDtMq89qM Attached thumbnail(s) |
| jimkelly |
Apr 5 2017, 06:15 AM
decided to try a microsquirt based on many youtube vids. seems i need to swap out my 6/7 crank sprocket for a 36-2-2-2 crank sprocket. this one.
based on this thread and below youtube vid. https://www.thesamba.com/vw/forum/viewtopic.php?p=5365250 spencer suggested this coil. coil 032906106b. it combines coil and exciter in one unit (IMG:style_emoticons/default/smile.gif) https://www.youtube.com/watch?v=wcek255pXHI http://www.tasteslikepetrol.net/2017/02/sp...coil-mount-cad/ ms coil info http://www.msextra.com/doc/pdf/html/Micros...are-3.4-62.html Attached thumbnail(s) Attached image(s)
| 76-914 |
Apr 5 2017, 07:59 AM
Good to see you haven't given up. MS is easier to wire. Do you have a map to emulate or will you be paying a tuner. (IMG:style_emoticons/default/beerchug.gif)
| jimkelly |
Apr 5 2017, 10:46 AM
guess i'll cross that bridge if i ever get there
but thanks for the encouragement (IMG:style_emoticons/default/smile.gif) i got 4 early ej22s, it would be ridiculous for me not to get one running using stand alone ecu. gonna spring for a microsquirt in next few weeks. very few sensors needed: throttle position sensor crank sensor coolant sensor intake air sensor gm 3 bar map sensor tach signal 2 banks of injectors a few relays fuel pump http://www.microsquirt.info/uswiring.htm a nice intake piece that might come in handy. http://www.atpturbo.com/mm5/merchant.mvc?S...;Category_Code= LS V8 info but decent explanation of relays in glove box https://www.youtube.com/watch?v=U_y4xuIVajQ Attached image(s)
| jpnovak |
Apr 5 2017, 02:48 PM
They call me "Nanoman" ![]() ![]() Group: Members Posts: 231 Joined: 26-August 09 From: Austin TX Member No.: 10,736 Region Association: Southwest Region |
MS2 ECU board fits nicely inside a stock Suby ECU case. (IMG:style_emoticons/default/smile.gif) This is what I ran on my EJ20TT motor in my old Suby conversion. Should have never sold that car. Anyway...
Just clip the stock connector and run jumper wires to the DB37 connector. Better capability than the microsquirt for boosted applications. for NA the microsquirt works just fine. |
Lo-Fi Version | Time is now: 25th September 2026 - 12:00 PM |
