Ex BUILD-OFF CHALLENGE: Brett's 914, Questions on metal prep |
brettrarnold |
Oct 1 2015, 12:24 AM
New 914 owner in Lakewood CO Group: Members Posts: 89 Joined: 11-September 15 From: Lakewood, Colorado Member No.: 19,149 Region Association: Rocky Mountains |
Background
This car was the first car that Brett drove when he was 13 and was given to us in 2014. It had been sitting idle back in Indiana under a family friend's carport for the past 15 years before Brett went back to Indiana and towed it out to Colorado with his father in July 2014. (IMG:style_emoticons/default/piratenanner.gif) When we got it, we didn't have a garage to work on it and it sat idle being stored outside for another year until we could afford a house with a garage. Colorado is pretty expensive so after we got a house with a garage, we then needed to save up more money to work on it. Also I must mention in my ignorance, there were 3 distinct phases of thinking for getting this car fixed which I now find funny and are listed below Phase 1: I will tow this car out to Colorado and get it the engine running for maybe $2,000 and have a working car. Phase 2: Holy shit after researching this is impossible and will have to pay somebody to fix it for $15-20k. Phase 3: I have enough local support and 914world resources and can fix this myself for around $10-15k. Build-Off Challenge So Amy and I are going to be tackling different aspects of this car so the posts will be coming from both of us. I will handling the rust/engine work and Amy will be on Interior and Exterior. Also she may help with some of the posting so we will start each post with name. Brett Step 1 (Complete) was to remove the engine and assess the frame rust situation. Never having removed an engine from a car, this was an extremely daunting task. The steps listed in Pelican Parts tutorial - 914 Engine Removal Made Easy is by far the most difficult thing I have done to a vehicle thus far. Hell I don't even know the difference between a camshaft and a carburetor much less a CV joint or a clutch cable. But after staring at it for about 2 weeks, I decided to just start unhooking shit and labeling. Made a ton of progress and finally got the engine about 95% unhooked. Had a friend come over to help me out and we actually got it out. WOOHOO!!! Step 2 (Complete) is to strip out all the interior. I ordered chassis braces and other misc items from Tangerine racing and am still in the process of identifying all the rust areas that need repair. Attached thumbnail(s) Attached image(s) |
rightpedal |
Jan 4 2016, 06:21 AM
rightpeda; Group: Members Posts: 60 Joined: 6-September 15 From: annapolis Member No.: 19,133 Region Association: MidAtlantic Region |
Saw the update about sawzal blades on the contest thread and I have thoughts. I do a lot of sawzal work and the only blade I use is the Milwaukee torch. They hold up really well. Look at my build thread all that was done with 3 blades. Part of your problem might be the Dewalt, They have notoriously sloppy blade holders. It shouldn't have any slop. The jig saw will provide more precision but will require a lot of patience. Given the nature of jig saws it will dull the blade quickly in the one little portion. If you don't have one you need to get a 4 1/2 angle grinder. Harbor freight has cut/grind/flap wheel combos that are a good intero pack.
Good luck with the project. Steve |
brettrarnold |
Mar 3 2016, 09:29 AM
Saw the update about sawzal blades on the contest thread and I have thoughts. I do a lot of sawzal work and the only blade I use is the Milwaukee torch. They hold up really well. Look at my build thread all that was done with 3 blades. Part of your problem might be the Dewalt, They have notoriously sloppy blade holders. It shouldn't have any slop. The jig saw will provide more precision but will require a lot of patience. Given the nature of jig saws it will dull the blade quickly in the one little portion. If you don't have one you need to get a 4 1/2 angle grinder. Harbor freight has cut/grind/flap wheel combos that are a good intero pack. Good luck with the project. Steve Ya i have had two blades that got stuck in that blade holder on that sawzall. A friend brought over some cutting wheels that attached to my grinder and my god that is the way to go. Thanks for the tip. Soo soo much easier. I feel like an idiot when i switch to something that works a million times better but oh well, all part of the process i suppose. Thanks Steve for the info. -Brett |
Lo-Fi Version | Time is now: 21st May 2024 - 08:17 AM |
