Ex BUILD-OFF CHALLENGE: Brett's 914, Questions on metal prep |
brettrarnold |
Oct 1 2015, 12:24 AM
New 914 owner in Lakewood CO Group: Members Posts: 89 Joined: 11-September 15 From: Lakewood, Colorado Member No.: 19,149 Region Association: Rocky Mountains |
Background
This car was the first car that Brett drove when he was 13 and was given to us in 2014. It had been sitting idle back in Indiana under a family friend's carport for the past 15 years before Brett went back to Indiana and towed it out to Colorado with his father in July 2014. (IMG:style_emoticons/default/piratenanner.gif) When we got it, we didn't have a garage to work on it and it sat idle being stored outside for another year until we could afford a house with a garage. Colorado is pretty expensive so after we got a house with a garage, we then needed to save up more money to work on it. Also I must mention in my ignorance, there were 3 distinct phases of thinking for getting this car fixed which I now find funny and are listed below Phase 1: I will tow this car out to Colorado and get it the engine running for maybe $2,000 and have a working car. Phase 2: Holy shit after researching this is impossible and will have to pay somebody to fix it for $15-20k. Phase 3: I have enough local support and 914world resources and can fix this myself for around $10-15k. Build-Off Challenge So Amy and I are going to be tackling different aspects of this car so the posts will be coming from both of us. I will handling the rust/engine work and Amy will be on Interior and Exterior. Also she may help with some of the posting so we will start each post with name. Brett Step 1 (Complete) was to remove the engine and assess the frame rust situation. Never having removed an engine from a car, this was an extremely daunting task. The steps listed in Pelican Parts tutorial - 914 Engine Removal Made Easy is by far the most difficult thing I have done to a vehicle thus far. Hell I don't even know the difference between a camshaft and a carburetor much less a CV joint or a clutch cable. But after staring at it for about 2 weeks, I decided to just start unhooking shit and labeling. Made a ton of progress and finally got the engine about 95% unhooked. Had a friend come over to help me out and we actually got it out. WOOHOO!!! Step 2 (Complete) is to strip out all the interior. I ordered chassis braces and other misc items from Tangerine racing and am still in the process of identifying all the rust areas that need repair. Attached thumbnail(s) Attached image(s) |
76-914 |
Oct 20 2015, 09:27 AM
Repeat Offender & Resident Subaru Antagonist Group: Members Posts: 13,504 Joined: 23-January 09 From: Temecula, CA Member No.: 9,964 Region Association: Southern California |
Unless you plan to AX the stock brakes are fine. I haven't seen Jeffs914's harness' but I can tell you that you can make your own harness (if you have a donor harness from the Subaru donor car) for pennies then tie into the existing 914 harness. (IMG:style_emoticons/default/beerchug.gif)
brettrarnold |
Sep 24 2023, 09:12 PM
Unless you plan to AX the stock brakes are fine. I haven't seen Jeffs914's harness' but I can tell you that you can make your own harness (if you have a donor harness from the Subaru donor car) for pennies then tie into the existing 914 harness. (IMG:style_emoticons/default/beerchug.gif) How do i tie into the existing 914 harness? |
mepstein |
Sep 24 2023, 10:22 PM
914-6 GT in waiting Group: Members Posts: 19,279 Joined: 19-September 09 From: Landenberg, PA/Wilmington, DE Member No.: 10,825 Region Association: MidAtlantic Region |
Unless you plan to AX the stock brakes are fine. I haven't seen Jeffs914's harness' but I can tell you that you can make your own harness (if you have a donor harness from the Subaru donor car) for pennies then tie into the existing 914 harness. (IMG:style_emoticons/default/beerchug.gif) How do i tie into the existing 914 harness? You don’t just tie in. You sit down with the harness and a Subaru wire schematic and 30-50 hours later, you have a harness that will plug into your car. Seriously, if you aren’t good at wire schematics, send it out to a pro. |
brettrarnold |
Sep 25 2023, 05:53 AM
Unless you plan to AX the stock brakes are fine. I haven't seen Jeffs914's harness' but I can tell you that you can make your own harness (if you have a donor harness from the Subaru donor car) for pennies then tie into the existing 914 harness. (IMG:style_emoticons/default/beerchug.gif) How do i tie into the existing 914 harness? You don’t just tie in. You sit down with the harness and a Subaru wire schematic and 30-50 hours later, you have a harness that will plug into your car. Seriously, if you aren’t good at wire schematics, send it out to a pro. I would be more than happy to send it to a pro... just need to find said pro! |
mepstein |
Sep 25 2023, 06:39 AM
Unless you plan to AX the stock brakes are fine. I haven't seen Jeffs914's harness' but I can tell you that you can make your own harness (if you have a donor harness from the Subaru donor car) for pennies then tie into the existing 914 harness. (IMG:style_emoticons/default/beerchug.gif) How do i tie into the existing 914 harness? You don’t just tie in. You sit down with the harness and a Subaru wire schematic and 30-50 hours later, you have a harness that will plug into your car. Seriously, if you aren’t good at wire schematics, send it out to a pro. I would be more than happy to send it to a pro... just need to find said pro! Jeff Robenolt jeffrobenolt@gmail.com Great guy, very experienced with Suby wire harness conversions. Way better than sending to smallcar. |
brettrarnold |
Sep 26 2023, 10:05 PM
Unless you plan to AX the stock brakes are fine. I haven't seen Jeffs914's harness' but I can tell you that you can make your own harness (if you have a donor harness from the Subaru donor car) for pennies then tie into the existing 914 harness. (IMG:style_emoticons/default/beerchug.gif) How do i tie into the existing 914 harness? You don’t just tie in. You sit down with the harness and a Subaru wire schematic and 30-50 hours later, you have a harness that will plug into your car. Seriously, if you aren’t good at wire schematics, send it out to a pro. I would be more than happy to send it to a pro... just need to find said pro! Jeff Robenolt jeffrobenolt@gmail.com Great guy, very experienced with Suby wire harness conversions. Way better than sending to smallcar. I sent Jeff an email but haven't heard anything back. Do you happen to have his number? |
Lo-Fi Version | Time is now: 21st May 2024 - 07:41 PM |
