BUILD-OFF CHALLENGE: Olympic Blue Resurrection, More Winter projects. |
Olympic 914 |
Oct 1 2015, 07:59 AM
Group: Members Posts: 1,662 Joined: 7-July 11 From: Pittsburgh PA Member No.: 13,287 Region Association: North East States |
2016 BUILD-OFF CHALLENGE Contender ... Olympic Blue Resurrection.
Purchased my 914 in 1979. It’s a 1973 base model 1.7 I’m the second owner. Original owner drove it for about 75K. In ’80 I slid off the road and went into a hillside, taking out the driver’s side fender. While in for that repair I decided to have some minor rust issues taken care of and had the whole car repainted. Back then lacquer was the hot set-up and it looked fantastic. Later while sitting in traffic a big Lincoln didn’t quite stop and pushed in the rear panel. Another trip to the body shop.. Then another time while driving home from work in the rain I hydroplaned coming out from under a bridge and clipped a jersey barrier. Minor damage to the pass. side, but again back to the body shop. So this car has seen its share of incidents over the years. I drove it for 10 years with only minor mechanical problems until the clutch went out 1989 and the engine had 137K on it. Then I was faced with low funds and engine that when removed will need rebuilding. So I put it in storage in a limestone mine in Bradys Bend PA. Figuring I would get it back out and get it running again one day. Here are the earliest pictures I could find. And the day I was taking it to the mines It wasn't supposed to be here this long.. Fast forward to 2010 -- Coming home. First daylight in 20+ years... I brought it home to a new 14 X20 SHED I had built just to work on the car. complete with 220V, phone and cable. After its first bath it doesn't look too bad. But in spite of being buried over 1 mile inside a mountain AND being in a temperature and humidity controlled storage the rust worms were still at work. albeit a little slower. Since that time I have had the extensive rust issues taken care of by Chris at Tangerine and also had the fenders flared for the 5 bolt Fuchs I will be running. I have completed the engine rebuild myself going from 1.7 into a 2056 with heads by HAM and a Raby 9590 cam, I am keeping the D-jet FI. I am now working on the body doing body work and paint. I AM NOT A BODY MAN. I really don’t even like body work but think I am capable. This is the hardest part for me. I would rather build engines. Most of my experience has been with Harley engines though and there just like big lawnmowers anyway... Along the way I am learning to weld, machine small parts and paint and acquiring many new tools. My own self-imposed goal was to drive it to 2016 Pittsburgh Vintage Grand Prix. Not sure if it will happen but without a goal it definitely WON’T happen. I will post more pictures of the progress I have already made on the car. This Build off Challenge will be just a little more incentive get out in the shed and work on the car. Wouldn't it be great to get 30 Teeners back on the road? Good luck to all participants and I welcome any interest and questions about how or why I did something Tom BTW did I mention I don't like body work.. |
Olympic 914 |
Jan 31 2017, 08:37 AM
Well its been a while since I updated this thread, but I haven't quit on it.
In the last installment I had painted up the hinge hardware. then after mounting them with the new rollers I noticed a crack on the passenger side trunk lid mount. I had already repaired the drivers side before painting it and had looked at the pass side then and it looked ok. ..... Well it wasn't. Fortunately I found it while I could still get in there, unfortunately it was previously repaired by brazing it (IMG:style_emoticons/default/mad.gif) So I had to grind out all the brass and get in there with the mig to fix it right. I am still learning with this mig but did manage to get in there, it should hold up now. Then I had to fix the paint I just burned up with the mig.... (IMG:style_emoticons/default/dry.gif) Since I had just picked up the doors from a local restoration shop that I had taken them to be blasted inside and out. I started on these. then found that the shop had added some warp to my doors when blasting them. (IMG:style_emoticons/default/headbang.gif) so they were going to need some more bodywork. They are ready now just waiting on some warmer temps to paint them (might be a couple months now) Worked on mounting the fuel pump and filter. not a lot of room with the sway bar there. After joining the engine and trans and strapping it to a cart, it started on its journey from the garage to the shed. I had to use the winch to pull the combo up the ramp into the shed, and into place under the car. Using a couple pieces of allthread on the front motor mounts and a floor jack under the trans, I was able to get the engine raised into place without damaging anything. (IMG:style_emoticons/default/biggrin.gif) although this is a slow method it gave me a lot of opportunity to make sure everything was clearing. I angled up one side first to clear the fuel injector lines and clear the tins on the suspension bolts. You can see the allthread still in place this picture above. It worked great.. |
Lo-Fi Version | Time is now: 7th May 2024 - 11:23 PM |
