BUILD-OFF CHALLENGE: Olympic Blue Resurrection, More Winter projects. |
Olympic 914 |
Oct 1 2015, 07:59 AM
Group: Members Posts: 1,662 Joined: 7-July 11 From: Pittsburgh PA Member No.: 13,287 Region Association: North East States |
2016 BUILD-OFF CHALLENGE Contender ... Olympic Blue Resurrection.
Purchased my 914 in 1979. It’s a 1973 base model 1.7 I’m the second owner. Original owner drove it for about 75K. In ’80 I slid off the road and went into a hillside, taking out the driver’s side fender. While in for that repair I decided to have some minor rust issues taken care of and had the whole car repainted. Back then lacquer was the hot set-up and it looked fantastic. Later while sitting in traffic a big Lincoln didn’t quite stop and pushed in the rear panel. Another trip to the body shop.. Then another time while driving home from work in the rain I hydroplaned coming out from under a bridge and clipped a jersey barrier. Minor damage to the pass. side, but again back to the body shop. So this car has seen its share of incidents over the years. I drove it for 10 years with only minor mechanical problems until the clutch went out 1989 and the engine had 137K on it. Then I was faced with low funds and engine that when removed will need rebuilding. So I put it in storage in a limestone mine in Bradys Bend PA. Figuring I would get it back out and get it running again one day. Here are the earliest pictures I could find. And the day I was taking it to the mines It wasn't supposed to be here this long.. Fast forward to 2010 -- Coming home. First daylight in 20+ years... I brought it home to a new 14 X20 SHED I had built just to work on the car. complete with 220V, phone and cable. After its first bath it doesn't look too bad. But in spite of being buried over 1 mile inside a mountain AND being in a temperature and humidity controlled storage the rust worms were still at work. albeit a little slower. Since that time I have had the extensive rust issues taken care of by Chris at Tangerine and also had the fenders flared for the 5 bolt Fuchs I will be running. I have completed the engine rebuild myself going from 1.7 into a 2056 with heads by HAM and a Raby 9590 cam, I am keeping the D-jet FI. I am now working on the body doing body work and paint. I AM NOT A BODY MAN. I really don’t even like body work but think I am capable. This is the hardest part for me. I would rather build engines. Most of my experience has been with Harley engines though and there just like big lawnmowers anyway... Along the way I am learning to weld, machine small parts and paint and acquiring many new tools. My own self-imposed goal was to drive it to 2016 Pittsburgh Vintage Grand Prix. Not sure if it will happen but without a goal it definitely WON’T happen. I will post more pictures of the progress I have already made on the car. This Build off Challenge will be just a little more incentive get out in the shed and work on the car. Wouldn't it be great to get 30 Teeners back on the road? Good luck to all participants and I welcome any interest and questions about how or why I did something Tom BTW did I mention I don't like body work.. |
Olympic 914 |
Aug 23 2016, 08:01 PM
Moved it outside for some pictures. paint turned out good. still will need a cut and buff.
And starting to put stuff back on... (IMG:style_emoticons/default/piratenanner.gif) Refinished the headlight mechanisms and got them installed. Had to hunt down some little parts, Thanks for friends with parts cars... I need to get one of those.. Installed the PMB 914/6 GT rear calipers and the vented rotors. also got all the hydraulic lines and hoses installed , glad I kept the old lines to use as a pattern. still need a couple little parts for the parking brake those rear calipers should play nice with the with the A calipers and vented rotors on the front. PMB also rebuilt my pressure regulator... Thanks Eric.. It is really great to empty out some boxes and get parts on the car... |
jkb944t |
Aug 26 2016, 10:48 AM
Member Group: Members Posts: 464 Joined: 17-January 05 From: Canton, OH Member No.: 3,459 Region Association: None |
Moved it outside for some pictures. paint turned out good. still will need a cut and buff. And starting to put stuff back on... (IMG:style_emoticons/default/piratenanner.gif) Refinished the headlight mechanisms and got them installed. Had to hunt down some little parts, Thanks for friends with parts cars... I need to get one of those.. Installed the PMB 914/6 GT rear calipers and the vented rotors. also got all the hydraulic lines and hoses installed , glad I kept the old lines to use as a pattern. still need a couple little parts for the parking brake those rear calipers should play nice with the with the A calipers and vented rotors on the front. PMB also rebuilt my pressure regulator... Thanks Eric.. It is really great to empty out some boxes and get parts on the car... You are making some huge progress! Jeff B |
Lo-Fi Version | Time is now: 26th April 2024 - 08:54 AM |
