BUILD-OFF CHALLENGE: Vysoc / Yellow Sub, And so it begins............ |
Vysoc |
Oct 2 2015, 01:48 PM
Vysoc Group: Members Posts: 586 Joined: 27-August 09 From: Young Harris, Georgia Member No.: 10,737 Region Association: South East States |
Here we go,
I bought this chassis several years ago and have been cutting out sections with rust. This roller was a 1976 with Fiberglas Flares, I like them. There is much work to be done. My 5 Major Project Points are: 1) Repair & Replace all rusted areas and weld in; * - New Floor Pans. *- Repairs to the Hell Hole area. *- Engman Kit. *- Weltmeister Chassis Stiffening Kit. *- McMark's Roll Bar. 2) Install Patrick Six Engine Mount, Install Engine, Have Transmission Rebuilt, Install Patrick Oil Tank and all Lines necessary, Install Oil Cooler, Rewire complete car. Replace and treat inside of Gas Tank, install new CF/ Fuel Lines. 3) Replace Doors, Windshield, Install Spartan Street/DE Interior, Sparco Vintage Seats, New Console, MoMo Wheel. 4) Prep car for Paint, all panels prepped, Hood, Trunk, Doors, Targa Top. 5) Replace & Upgrade all Suspension, Brakes, Bushings, Wheels & Tires. |
Vysoc |
Oct 22 2015, 05:27 AM
OK,
Day off today, my season is just starting (Golf in Florida) as the temps have finally dropped, hell it got down to 68 degrees the other morning almost a cold front which means the garage only gets up to 90. October for me has been a reorganization month in the garage to get my White 75 placed in another garage so that I can spread things out and have some working room. That said and done, I now have my garage in a position to work, just cut out the Driver's side Cross Brace that was heavily rusted and have fitted up the Restoration Design replacement piece. I also fitted up the drivers side floorboards, I have more trimming to do to the old floor pan to get things in a position where I can use Clecos to fit them properly. I was also able to pick up a Miller TIG Welder and I need to get up to speed on it, I do not have a 220V feed in my garage so I have moved my Hurricane Generator in place to power that thing from outside the garage. I have several areas on the car that I believe will benefit from TIG rather than MIG as the heat from MIG causes alot of Blow through and warping. So today will be a day to learn my new/old used machine and trim the rest of the old floor pan out, I may even get something welded today. Photo's of updates forth coming. Slowly moving forward! Vysoc (IMG:style_emoticons/default/flag.gif) (IMG:style_emoticons/default/welder.gif) |
Lo-Fi Version | Time is now: 19th May 2024 - 12:18 PM |
