My tire options and fitment. |
patssle |
Oct 4 2015, 01:38 PM
Senior Member Group: Members Posts: 981 Joined: 28-August 09 From: Houston, TX Member No.: 10,741 Region Association: None |
I'm currently running 185/65-15 cheapo tires. I want to upgrade to some performance tires (g-Force Sport COMP-2) and the only size I can get is 195/55-15. My passenger rear tire has the closest gap between the tire and fender being about 1/2" calculating for the widest part of the tire. None of the gaps on the other tires are the same and all are bigger. Also my rear tires have a rather significant negative camber as my inside threads are significantly more worn than the outside.
Should I be concerned about changing tire size at all and especially if I get an alignment which may reduce the camber (so the top part of the tire would be moved outwards)? |
EdwardBlume |
Oct 5 2015, 12:42 PM
I ran 195 60 15s on racing tires and was tight with 1/4 spacers. I ran 205 60 15s on street tires and was really tight with 1/4 spacers.
Results may vary. Dave is right about having to roll the fenders, but not on every corner. I was OK on one side, but not on the other. |
Lo-Fi Version | Time is now: 18th May 2024 - 07:18 PM |
