My tire options and fitment. |
patssle |
Oct 4 2015, 01:38 PM
Senior Member Group: Members Posts: 981 Joined: 28-August 09 From: Houston, TX Member No.: 10,741 Region Association: None |
I'm currently running 185/65-15 cheapo tires. I want to upgrade to some performance tires (g-Force Sport COMP-2) and the only size I can get is 195/55-15. My passenger rear tire has the closest gap between the tire and fender being about 1/2" calculating for the widest part of the tire. None of the gaps on the other tires are the same and all are bigger. Also my rear tires have a rather significant negative camber as my inside threads are significantly more worn than the outside.
Should I be concerned about changing tire size at all and especially if I get an alignment which may reduce the camber (so the top part of the tire would be moved outwards)? |
patssle |
Oct 5 2015, 05:08 PM
Yeah it definitely has a nice lip that would be ruined. Do I need a body guy to pull the fender out without touching the lip? I've never done any body work. It looks like my drivers side sticks further out which explains the increased gap over the passenger side. I don't know the history of the car so who knows what is original or if it has been hit.
Lo-Fi Version | Time is now: 26th May 2024 - 06:59 AM |
