My tire options and fitment. |
patssle |
Oct 4 2015, 01:38 PM
Senior Member Group: Members Posts: 981 Joined: 28-August 09 From: Houston, TX Member No.: 10,741 Region Association: None |
I'm currently running 185/65-15 cheapo tires. I want to upgrade to some performance tires (g-Force Sport COMP-2) and the only size I can get is 195/55-15. My passenger rear tire has the closest gap between the tire and fender being about 1/2" calculating for the widest part of the tire. None of the gaps on the other tires are the same and all are bigger. Also my rear tires have a rather significant negative camber as my inside threads are significantly more worn than the outside.
Should I be concerned about changing tire size at all and especially if I get an alignment which may reduce the camber (so the top part of the tire would be moved outwards)? |
Dave_Darling |
Oct 7 2015, 02:46 PM
914 Idiot Group: Members Posts: 14,986 Joined: 9-January 03 From: Silicon Valley / Kailua-Kona Member No.: 121 Region Association: Northern California |
That's nice for your car, but 914s differ from car to car. And even from side to side on the same car! There are no guarantees about tire fitment...
--DD |
markyb |
Oct 7 2015, 03:23 PM
Member Group: Members Posts: 100 Joined: 27-November 11 From: Rochester, Michigan Member No.: 13,823 Region Association: None |
That's nice for your car, but 914s differ from car to car. And even from side to side on the same car! There are no guarantees about tire fitment... --DD Dave, My thinking was that OP would know roughly where his fenders should be vs. where they are now since we have similar rims and tires, that way he only moves the metal where needed. The tough part, as he is requesting, is how to move it |
Lo-Fi Version | Time is now: 18th May 2024 - 08:59 PM |
