Oil Cooler for 2366? |
VWTortuga336 |
Oct 4 2015, 07:49 PM
Member Group: Members Posts: 285 Joined: 5-October 14 From: Kansas City, Missouri Member No.: 17,979 Region Association: None |
What would be my best solution for adding an oil cooler on the 2366 build I am starting? I've read about coolers that mount under the rear of the car and are cooled with a fan. Is this the right direction?
Dave_Darling |
Oct 5 2015, 09:14 AM
914 Idiot Group: Members Posts: 14,981 Joined: 9-January 03 From: Silicon Valley / Kailua-Kona Member No.: 121 Region Association: Northern California |
Probably not.
The amount of oil cooling an engine needs can vary quite a bit, depending on a ton and a half of things. So just seeing "2366" won't tell us how much cooling the engine needs. But chances are that it will need a pretty decent amount, and under the trunk floor is far from the best location for the cooler. You ideally want the cooler to get a good supply of cool, clean, high-pressure air. Under the trunk floor it will get an indifferent supply of air warmed up by the engine and especially the exhaust. The fan helps, but only so much. That setup is a compromise, and is generally used when there are other constraints that need to be satisfied. In my case, for instance, I did not want to run hoses forward in the car, nor cut holes for the air ducting. Mine is almost adequate for my particular 2.0 engine. If I had to pick a setup for your car, I would say that you need to run a front-mounted cooler. It doesn't have to be a 914-6GT style, but that is a very well known setup. You need to duct air to the cooler, and duct the warmed-up air out from the cooler. You will lose some front trunk space to do it, though. --DD |
Dion |
Oct 5 2015, 09:16 AM
RN Group: Members Posts: 2,763 Joined: 16-September 04 From: Audubon,PA Member No.: 2,766 Region Association: MidAtlantic Region |
I have hi-comp 96mm P&C "2056".
914Dave & I came up with this setup to keep my oil temps healthy. Originally just a Mocal cooler sitting next to trans. When I upgraded to the "2056" we added the electric fan and shroud/box. Never really above 220F on a hot run, on a 90F day. Stays between 180-210F per the vdo gauge. This works for my set up. Not knowing your set. I imagine the heat units will be greater. Maybe trombone or other 911 style setup toward front for more volume of cooling air. Good luck. Cheers, Dion Attached thumbnail(s) |
VaccaRabite |
Oct 5 2015, 10:07 AM
En Garde! Group: Admin Posts: 13,430 Joined: 15-December 03 From: Dallastown, PA Member No.: 1,435 Region Association: MidAtlantic Region |
Tell us about your 2366.
I would imagine that it will need a bow mounted oil cooler - thats a lot of displacement for a T4. Most of us running stern mounts are cooling 2L engines that don't need a lot of extra cooling to begin with. Zach |
VWTortuga336 |
Oct 5 2015, 10:57 AM
Tell us about your 2366. Sorry about that, I should have told you more to begin with. Here's what I'm building: Stock 71mm crank Stock 2.0L connecting rods Stock 2.0L 3 bolt heads with new 36/42 valves Forged JE 103mm pistons Cast iron 103mm cylinders SCAT C35 cam - .495" lift, 285 duration (matching lifters) Weber 44 IDFs Stock flywheel Bursch exhaust 2.0 SS heat exchangers |
Dave_Darling |
Oct 5 2015, 04:55 PM
Put the cooler up front, and hope. The cast-iron 103s aren't known for running cool.
--DD |
Reno914 |
Oct 5 2015, 05:00 PM
Newbie Group: Members Posts: 31 Joined: 18-August 09 From: Reno Member No.: 10,694 Region Association: Northern California |
Are you planning on running the stock fan and cooling for the engine, or is that planned to be upgraded with a DTM, or a Tangerine horizontal system?
Big engines require big cooling. Reno |
ConeDodger |
Oct 5 2015, 05:06 PM
Apex killer! Group: Members Posts: 23,569 Joined: 31-December 04 From: Tahoe Area Member No.: 3,380 Region Association: Northern California |
Put the cooler up front, and hope. The cast-iron 103s aren't known for running cool. --DD And by "not known for running cool," he means they are known for running hot. (IMG:style_emoticons/default/blink.gif) |
VWTortuga336 |
Oct 5 2015, 07:51 PM
Mueller |
Oct 5 2015, 07:58 PM
r_towle |
Oct 5 2015, 08:18 PM
Custom Member Group: Members Posts: 24,569 Joined: 9-January 03 From: Taxachusetts Member No.: 124 Region Association: North East States |
Put the cooler up front, and hope. The cast-iron 103s aren't known for running cool. --DD And by "not known for running cool," he means they are known for running hot. (IMG:style_emoticons/default/blink.gif) A design that worked for almost 30 years. Put the cooler up front and don't fear the cast iron cylinders. Rich |
VWTortuga336 |
Oct 5 2015, 08:21 PM
Put the cooler up front, and hope. The cast-iron 103s aren't known for running cool. --DD When you say "up front" at what point do people just mount between bumper and chassis and at what point is the cooler installed in the front trunk with ducting? I have the same question. If someone could give me some more direction on this setup, I'd appreciate it. |
Dave_Darling |
Oct 5 2015, 08:29 PM
r_towle |
Oct 5 2015, 08:39 PM
A design that worked for almost 30 years. 30 years, 1/4 mile at a time... --DD Have you owned one? I have and still do. Built a few more that are still out there running around. You are spreading another myth, and it's sad coming from you. |
Dion |
Oct 5 2015, 08:56 PM
Put the cooler up front, and hope. The cast-iron 103s aren't known for running cool. --DD When you say "up front" at what point do people just mount between bumper and chassis and at what point is the cooler installed in the front trunk with ducting? I have the same question. If someone could give me some more direction on this setup, I'd appreciate it. PM sent. |
ChrisFoley |
Oct 6 2015, 06:28 AM
I am Tangerine Racing Group: Members Posts: 7,911 Joined: 29-January 03 From: Bolton, CT Member No.: 209 Region Association: None |
VWTortuga336 |
Oct 6 2015, 07:00 AM
JmuRiz |
Oct 6 2015, 08:26 AM
914 Guru Group: Members Posts: 5,424 Joined: 30-December 02 From: NoVA Member No.: 50 Region Association: MidAtlantic Region |
Give Racer Chris a call and he'll come up with a setup to help your big 4 exhale better...can even have heat boxes put on.
wndsrfr |
Oct 6 2015, 10:56 AM
Senior Member Group: Members Posts: 1,428 Joined: 30-April 09 From: Rescue, Virginia Member No.: 10,318 Region Association: MidAtlantic Region |
Give Racer Chris a call and he'll come up with a setup to help your big 4 exhale better...can even have heat boxes put on. (IMG:style_emoticons/default/agree.gif) My 2316 has the Tangerine Evo .... That along with the big ITB's put out 165hp at the wheels....and the sound will put a smile on your face that you can't wipe off with a handful of hundred dollar bills! |
Dave_Darling |
Oct 6 2015, 02:46 PM
Have you owned one? I have and still do. So you have an engine running 103mm cast-iron cylinders for the past 30 years? For 100K miles or more? Impressive if so. The "1/4 mile at a time" was an exaggeration, for effect. The fact remains that the QC on the 103s and 105s that we could get for so long was pretty miserable. They also have smaller fins to still fit under stock tins, which doesn't help with heat. Do they all have heat issues? Probably not. But I'd bet that the ones that don't either live in a nice cool climate, or had a whole lot of attention paid to the details of the configuration and setup. Details that, sad to say, most people don't seem to bother with. So, I will retate an opinion--if you are running a 103x71 motor, put a big cooler on it, and hope. Unless you've sunk serious bucks into it, you have pretty strong odds of it running hot and living a short life. --DD |
Lo-Fi Version | Time is now: 29th April 2024 - 02:03 PM |
