Oil Cooler for 2366? |
VWTortuga336 |
Oct 4 2015, 07:49 PM
Member Group: Members Posts: 285 Joined: 5-October 14 From: Kansas City, Missouri Member No.: 17,979 Region Association: None |
What would be my best solution for adding an oil cooler on the 2366 build I am starting? I've read about coolers that mount under the rear of the car and are cooled with a fan. Is this the right direction?
VaccaRabite |
Oct 5 2015, 10:07 AM
En Garde! Group: Admin Posts: 13,443 Joined: 15-December 03 From: Dallastown, PA Member No.: 1,435 Region Association: MidAtlantic Region |
Tell us about your 2366.
I would imagine that it will need a bow mounted oil cooler - thats a lot of displacement for a T4. Most of us running stern mounts are cooling 2L engines that don't need a lot of extra cooling to begin with. Zach |
VWTortuga336 |
Oct 5 2015, 10:57 AM
Tell us about your 2366. Sorry about that, I should have told you more to begin with. Here's what I'm building: Stock 71mm crank Stock 2.0L connecting rods Stock 2.0L 3 bolt heads with new 36/42 valves Forged JE 103mm pistons Cast iron 103mm cylinders SCAT C35 cam - .495" lift, 285 duration (matching lifters) Weber 44 IDFs Stock flywheel Bursch exhaust 2.0 SS heat exchangers |
ChrisFoley |
Oct 6 2015, 06:28 AM
I am Tangerine Racing Group: Members Posts: 7,925 Joined: 29-January 03 From: Bolton, CT Member No.: 209 Region Association: None |
Lo-Fi Version | Time is now: 16th May 2024 - 02:47 AM |
