Oil Cooler for 2366? |
VWTortuga336 |
Oct 4 2015, 07:49 PM
Member Group: Members Posts: 285 Joined: 5-October 14 From: Kansas City, Missouri Member No.: 17,979 Region Association: None |
What would be my best solution for adding an oil cooler on the 2366 build I am starting? I've read about coolers that mount under the rear of the car and are cooled with a fan. Is this the right direction?
ThePaintedMan |
Oct 6 2015, 09:12 PM
Advanced Member Group: Members Posts: 3,886 Joined: 6-September 11 From: St. Petersburg, FL Member No.: 13,527 Region Association: South East States |
Shane (Jetsetsurfshop) built a similar engine for his car. He tried all kinds of arrangements of ducting for a rear-mounted cooler. Found out he could only keep it cool with a front-mounted cooler. Granted, this is a track car, but even on the street, that's a lot of heat for a rear-mounted setup to deal with. Yes, the plumbing sucks, but in the long run, I still think it's better to just get it up front where it belongs.
VWTortuga336 |
Oct 7 2015, 08:43 AM
I still think it's better to just get it up front where it belongs. That seems to be the concensus. Any suggestions on how to accomplish this? If I do a front cooler, how do I keep the hot air from just getting hung up in the trunk? What about putting the cooler in the floor of the trunk, rather than the front of the car? |
Dave_Darling |
Oct 7 2015, 02:55 PM
914 Idiot Group: Members Posts: 14,986 Joined: 9-January 03 From: Silicon Valley / Kailua-Kona Member No.: 121 Region Association: Northern California |
If I do a front cooler, how do I keep the hot air from just getting hung up in the trunk? What about putting the cooler in the floor of the trunk, rather than the front of the car? The factory racers put the cooler at the very front of the front trunk. They cut holes for the air coming in, had ducting to make sure the air went through the cooler, then more ducting to run the air out the trunk floor. That's pretty much the "proper" way to do it. You can probably do much the same thing, and have the cooler on the trunk floor instead of at the front of the trunk. I suspect that the cooling effect will be about the same, because the air flow will be about the same, but I could be wrong. I've only seen a couple of 914s with coolers in front of the body. One had it mounted as a very thick license plate bracket; that seemed to work pretty decently in the Pac NW. Others have put them in cut-out fiberglass versions of the 75-76 Rubber Baby Buggy Bumpers. Not sure how the air was ducted away from those. They were there because of racing rules that prohibited holes in the body for cooling air. --DD |
Lo-Fi Version | Time is now: 16th May 2024 - 01:11 PM |
