MalloryUnilite Review @ Question, Can it get better??? |
catsltd |
Oct 5 2015, 09:11 PM
Member Group: Members Posts: 181 Joined: 7-June 15 From: Calgary Alberta Member No.: 18,814 Region Association: None |
1974 1.8L Petronix pointless ignition.
Bought a Mallory 4554101 Please dont ask what it cost. Anyway Review:Mallory Unilite. 1.Car starts easier. 2.very linear power,much more power below 3000 RPM. 3.Drives much nicer. 4.Supper easy install,if I can do it anyone can.(Although I have no idea what I did to get it running right,besides timing 7.5 BTDC. 5.Best bang for the buck bar none. Question: What are the Grey springs????, Are they worth trying to install over the stock springs in the Mallory. Car does not have a lot more power in 5th gear,so wondering what the gray springs might do. Any information would be appreciated. |
pete000 |
Oct 5 2015, 11:26 PM
I just installed Pertronix kit in my 74 1.8 but was considering the Mallory set up.
I would be interested on hearing more about your experiences as you tune it. Why did you not go with a vacuum advance unit? I have read true mechanical advance is not good for typical street use, but I have also read that the 74 914 1.8 did not use vacuum advance only retard. (A Hot topic of debate) Attached image(s) |
porschetub |
Oct 6 2015, 02:16 AM
Advanced Member Group: Members Posts: 4,695 Joined: 25-July 15 From: New Zealand Member No.: 18,995 Region Association: None |
I just installed Pertronix kit in my 74 1.8 but was considering the Mallory set up. I would be interested on hearing more about your experiences as you tune it. Why did you not go with a vacuum advance unit? I have read true mechanical advance is not good for typical street use, but I have also read that the 74 914 1.8 did not use vacuum advance only retard. (A Hot topic of debate) A stock one cleaned up with pertronix should perform the same but that's maybe just me trying to be a tightass,thinking you could spend money elsewhere unless the advance curve is better than the Bosch. |
jim_hoyland |
Oct 6 2015, 06:29 AM
Get that VIN ? Group: Members Posts: 9,225 Joined: 1-May 03 From: Sunset Beach, CA Member No.: 643 Region Association: Southern California |
[quote name='porschetub' date='Oct 6 2015, 01:16 AM' post='2248226']
[quote name='pete000' post='2248205' date='Oct 6 2015, 06:26 PM'] A stock one cleaned up with pertronix should perform the same but that's maybe just me trying to be a tightass,thinking you could spend money elsewhere unless the advance curve is better than the Bosch. [/quote] (IMG:style_emoticons/default/agree.gif) I got the same results after installation of the Mallory Unilite. Plus, I no longer get pinging on hills and the engine runs on the cool side. After the Unilite install, I disconnected my MSD ignition. Still runs great. Be sure to carry a spare optical module. |
Jake Raby |
Oct 6 2015, 07:40 AM
You got lucky... MSD bought Mallory and killed the 4554101 unit. There are no more being made.
Nothing I have found compares with the Mallory 4554101 for simplicity, tune ability, and effectiveness. The stock distributor does not have tight enough tolerances, and distributor cap terminals are too close together to compare to the Mallory. The Mallory is an exceptional unit to control spark scatter, especially at high RPM. Nothing is better for timing accuracy, than controlling spark scatter. If you have a Mallory, hold onto it.. If you can still find one today, you better buy it. The MSD unit they have substituted for it does not fit with stock cooling systems, does not have the proper distributor clamp, and uses a hall effect sensor, not an optical sensor. It is no where near as tunable, and is pretty much set up for a drag race style application. I have never favored the MSD units, even in applications where they would fit. Another good part is gone. |
catsltd |
Oct 6 2015, 08:53 AM
I just installed Pertronix kit in my 74 1.8 but was considering the Mallory set up. I would be interested on hearing more about your experiences as you tune it. Why did you not go with a vacuum advance unit? I have read true mechanical advance is not good for typical street use, but I have also read that the 74 914 1.8 did not use vacuum advance only retard. (A Hot topic of debate) I had run my Petronix for about 1 month now,already changed injectors connectors,plugs,wires coil. The problem was It felt like I had no advance when running. Car was just slow very little power off the line or climbing hills. I have one line from my throttle body to my 1 advance line on my distributor,and it made no difference plugging it in or leaving it unplugged when timing car,or running the car. So from all the reading I did, it sounded like the Unilite was the way to go. And it is. When I say the car has more power,I am guessing the advance is working like its supposed to Now. What used to take 1/2 throttle to go through the gears now takes 1/4 gas. I have it timed off the red mark on the fan. On the 1.8L this is the 7.5 degree mark. Anyway if you can find one get one. I tried to buy one from Aircooled but I think they thought they could not get me one. But they did eventually find me one,but had bought one off ebay by then. When I bought the car 3 months ago I had no idea it could be so much more fun to drive than when I bought it. Car is running like a top,besides the oil leaks I could not be more happy. I take Zero credit for any of it though,I did the labor but everyone hear told me how to do it. So Thanks . |
catsltd |
Oct 6 2015, 08:59 AM
You got lucky... MSD bought Mallory and killed the 4554101 unit. There are no more being made. Nothing I have found compares with the Mallory 4554101 for simplicity, tune ability, and effectiveness. The stock distributor does not have tight enough tolerances, and distributor cap terminals are too close together to compare to the Mallory. The Mallory is an exceptional unit to control spark scatter, especially at high RPM. Nothing is better for timing accuracy, than controlling spark scatter. If you have a Mallory, hold onto it.. If you can still find one today, you better buy it. The MSD unit they have substituted for it does not fit with stock cooling systems, does not have the proper distributor clamp, and uses a hall effect sensor, not an optical sensor. It is no where near as tunable, and is pretty much set up for a drag race style application. I have never favored the MSD units, even in applications where they would fit. Another good part is gone. I did not get lucky LOL. I saw a new one on Ebay,maybe 30 people looking at it,did not wait just bought it. Converted to Canadian dollars with duty and shipping it was not a good deal,but glad I bought it just the same. I know you setup all your Mallory distributors in house,but do you recommend leaving it stock or should I try the gray springs from aircooled.net.??/.any help would be appreciated. Thanks Grant. |
catsltd |
Oct 6 2015, 09:13 AM
I just installed Pertronix kit in my 74 1.8 but was considering the Mallory set up. I would be interested on hearing more about your experiences as you tune it. Why did you not go with a vacuum advance unit? I have read true mechanical advance is not good for typical street use, but I have also read that the 74 914 1.8 did not use vacuum advance only retard. (A Hot topic of debate) A stock one cleaned up with pertronix should perform the same but that's maybe just me trying to be a tightass,thinking you could spend money elsewhere unless the advance curve is better than the Bosch. New alternator,new plug wires,new Alternator harness from the guy who makes them here,new motor ground,new alternator ground,,new injectors,new injector connectors,new plugs,new fuel lines,Pertronix. Car was running pretty good. Add a Unilite,car runs Really Really good. Starts and runs,no stumbling trying to find idle at startup,no RPM surges,rock solid idle all the time cold or hot.Can pull from below 2000 without bucking. The only problem I have is in 5th gear climbing a hill at 70 MPH at about 3100 RPM it does not have a lot of power. From what I have been reading I probably should be down shifting???. |
bretth |
Oct 6 2015, 10:20 AM
Senior Member Group: Members Posts: 899 Joined: 23-June 15 From: Central TX Member No.: 18,882 Region Association: Southwest Region |
Since this is now no longer manufactured. I wonder how long before replacement distributor caps are no longer available.
Brett |
ChrisFoley |
Oct 6 2015, 10:30 AM
I am Tangerine Racing Group: Members Posts: 7,894 Joined: 29-January 03 From: Bolton, CT Member No.: 209 Region Association: None |
Jake Raby |
Oct 6 2015, 10:33 AM
You got lucky... MSD bought Mallory and killed the 4554101 unit. There are no more being made. Nothing I have found compares with the Mallory 4554101 for simplicity, tune ability, and effectiveness. The stock distributor does not have tight enough tolerances, and distributor cap terminals are too close together to compare to the Mallory. The Mallory is an exceptional unit to control spark scatter, especially at high RPM. Nothing is better for timing accuracy, than controlling spark scatter. If you have a Mallory, hold onto it.. If you can still find one today, you better buy it. The MSD unit they have substituted for it does not fit with stock cooling systems, does not have the proper distributor clamp, and uses a hall effect sensor, not an optical sensor. It is no where near as tunable, and is pretty much set up for a drag race style application. I have never favored the MSD units, even in applications where they would fit. Another good part is gone. I did not get lucky LOL. I saw a new one on Ebay,maybe 30 people looking at it,did not wait just bought it. Converted to Canadian dollars with duty and shipping it was not a good deal,but glad I bought it just the same. I know you setup all your Mallory distributors in house,but do you recommend leaving it stock or should I try the gray springs from aircooled.net.??/.any help would be appreciated. Thanks Grant. The grey springs make a big difference. We have gone to a crank trigger now that all these Mallory units are gone for good. |
Porschef |
Oct 6 2015, 10:38 AM
How you doin' Group: Members Posts: 2,162 Joined: 7-September 10 From: LawnGuyland Member No.: 12,152 Region Association: North East States |
In what condition was your original unit? Had you ever tried to clean and lube it?
(IMG:style_emoticons/default/popcorn[1].gif) |
sean_v8_914 |
Oct 6 2015, 11:35 AM
i needed a dizzy so i reached into my stash. i had 10+ or so. it took 4 to make one good one. all the shims and washers and advance plates and...are broken or worn or...
has anyone tried that cb performance programmable thing? http://www.cbperformance.com/SearchResults.asp?Cat=218 |
pete000 |
Oct 6 2015, 11:48 AM
Figures by the time I figure out what works they are NLA
mrfourteen |
Oct 6 2015, 11:52 AM
Member Group: Members Posts: 74 Joined: 1-November 13 From: Oregon out in the Mozarks Member No.: 16,596 Region Association: Pacific Northwest |
there is always Crankfire!
Ford EDIS with Megajolt controller. I use it on everything, flawless spark control. |
ChrisFoley |
Oct 6 2015, 01:00 PM
Figures by the time I figure out what works they are NLA We're getting ready to test a MSD distributor on a customer engine. Here are my observations so far: They seem made to better QA standards than Mallory. Spark plug wires need to be changed since the MSD cap uses HEI style contacts. Only a very minor tin adjustment is required for the cap to fit, no different than for a Mallory. Total advance and curve are user adjustable just like Mallory. Only a minor change is required for the distributor to clamp down to the engine case correctly. A MSD CD box is required, making the installed product more expensive than the Mallory, but you get a rev limiter as an added bonus. |
JimN73 |
Oct 6 2015, 01:13 PM
Senior Member Group: Members Posts: 535 Joined: 6-October 07 From: Gig Harbor Member No.: 8,192 Region Association: Pacific Northwest |
Make sure that the coil you use is a 1.5 ohm coil. Bosch Blue coils and others generally used for other distributors are 3 ohm coils and will fry your Mallory on a stormy March afternoon during rush hour.
ChrisFoley |
Oct 6 2015, 01:25 PM
Make sure that the coil you use is a 1.5 ohm coil. Bosch Blue coils and others generally used for other distributors are 3 ohm coils and will fry your Mallory on a stormy March afternoon during rush hour. Our experience has been that Bosch blue coils are the best choice with a Mallory Distr. |
Jake Raby |
Oct 6 2015, 01:34 PM
I evaluated the MSD distributor replacement last week. Wasn't pleased with the results at all. They swore to us that the unit was different than the standard old T1 unit they had been supplying for fitment to the T4. This was;t the case, it compared perfectly to a T1 unit that I have had since 2007 in the dyno cell.
Some people may like them, because they can make more profit selling them. |
DBCooper |
Oct 6 2015, 03:20 PM
I evaluated the MSD distributor replacement last week. Wasn't pleased with the results at all. They swore to us that the unit was different than the standard old T1 unit they had been supplying for fitment to the T4. This was;t the case, it compared perfectly to a T1 unit that I have had since 2007 in the dyno cell. Some people may like them, because they can make more profit selling them. You said you only sell crankfire? And there's less profit in that? |
Lo-Fi Version | Time is now: 28th March 2024 - 07:12 PM |
