MalloryUnilite Review @ Question, Can it get better??? |
catsltd |
Oct 6 2015, 04:30 PM
Member Group: Members Posts: 181 Joined: 7-June 15 From: Calgary Alberta Member No.: 18,814 Region Association: None |
Make sure that the coil you use is a 1.5 ohm coil. Bosch Blue coils and others generally used for other distributors are 3 ohm coils and will fry your Mallory on a stormy March afternoon during rush hour. I run a 3-ohm Petronix. That way I dont need a ballist resister in line. At least that what I have read is the proper way to do it.?? Hope thats correct. |
JimN73 |
Oct 6 2015, 06:02 PM
Senior Member Group: Members Posts: 535 Joined: 6-October 07 From: Gig Harbor Member No.: 8,192 Region Association: Pacific Northwest |
Make sure that the coil you use is a 1.5 ohm coil. Bosch Blue coils and others generally used for other distributors are 3 ohm coils and will fry your Mallory on a stormy March afternoon during rush hour. Our experience has been that Bosch blue coils are the best choice with a Mallory Distr. My ignition module is #605. Must be different from the one you use. Here's the bit from the installation instructions. Replacement UNILITE module. For all MALLORY UNILITE distributors, and Conversion Kits. Requires a 1.4ohms Ballast resistor, Loom resistor, or internally resisted coil. Also can replace the ACCEL Point Eliminator kit module. Replacement UNILITE module. For all MALLORY UNILITE distributors, and Conversion Kits. Requires a 1.4ohms Ballast resistor, Loom resistor, or internally resisted coil. |
Jake Raby |
Oct 6 2015, 10:50 PM
I evaluated the MSD distributor replacement last week. Wasn't pleased with the results at all. They swore to us that the unit was different than the standard old T1 unit they had been supplying for fitment to the T4. This was;t the case, it compared perfectly to a T1 unit that I have had since 2007 in the dyno cell. Some people may like them, because they can make more profit selling them. You said you only sell crankfire? And there's less profit in that? I haven't sold a single part in almost 3 years. LN Engineering has owned the Type 4 Store since 2013.... We use crank triggered arrangements on turnkey engines. |
AndyB |
Oct 7 2015, 05:54 AM
The Governor is watching me Group: Members Posts: 1,115 Joined: 10-April 10 From: Philadelphia New York Member No.: 11,595 Region Association: North East States |
I evaluated the MSD distributor replacement last week. Wasn't pleased with the results at all. They swore to us that the unit was different than the standard old T1 unit they had been supplying for fitment to the T4. This was;t the case, it compared perfectly to a T1 unit that I have had since 2007 in the dyno cell. Some people may like them, because they can make more profit selling them. Wow and you sell what again for huge profits? |
catsltd |
Oct 7 2015, 09:09 AM
Make sure that the coil you use is a 1.5 ohm coil. Bosch Blue coils and others generally used for other distributors are 3 ohm coils and will fry your Mallory on a stormy March afternoon during rush hour. Our experience has been that Bosch blue coils are the best choice with a Mallory Distr. My ignition module is #605. Must be different from the one you use. Here's the bit from the installation instructions. Replacement UNILITE module. For all MALLORY UNILITE distributors, and Conversion Kits. Requires a 1.4ohms Ballast resistor, Loom resistor, or internally resisted coil. Also can replace the ACCEL Point Eliminator kit module. Replacement UNILITE module. For all MALLORY UNILITE distributors, and Conversion Kits. Requires a 1.4ohms Ballast resistor, Loom resistor, or internally resisted coil. So I am kind of lost now. My coil has 3 ohm resistance. Do I still need another resistor in line on top of the 3ohm from my coil.Thanks Sorry for not understanding correctly. |
era vulgaris |
Oct 7 2015, 04:13 PM
J is for Genius Group: Members Posts: 982 Joined: 10-November 13 From: Raleigh, NC Member No.: 16,629 Region Association: South East States |
Hmmmm....I'm using the MSD Blaster 2 coil with my Mallory Unilite. It's 0.7 ohms. But I've also got an MSD 6AL ignition module. I still haven't quite figured out what the PO was up to adding the 6AL (IMG:style_emoticons/default/confused24.gif) I don't think it's really needed, is it?
At any rate, I've had no problems so far with it. |
catsltd |
Oct 7 2015, 04:58 PM
http://vwparts.aircooled.net/Mallory-Distr...e-p/4554101.htm.
This says it can be used with any coil with a resister of 1.5 ohm or more. If you have a coil with 1.5 ohm or more itcan be run as a stand alone. Ill order a spare optical and a surge protection,but last I heard from air cool was 5 weeks out for a surge protector from Mallory. Anyway hope it works okay,so far so good. If I am wrong Ill sure make sure to let yo guys know. Thanks for all your help. |
jim_hoyland |
Oct 8 2015, 06:30 AM
Get that VIN ? Group: Members Posts: 9,258 Joined: 1-May 03 From: Sunset Beach, CA Member No.: 643 Region Association: Southern California |
Hmmmm....I'm using the MSD Blaster 2 coil with my Mallory Unilite. It's 0.7 ohms. But I've also got an MSD 6AL ignition module. I still haven't quite figured out what the PO was up to adding the 6AL (IMG:style_emoticons/default/confused24.gif) I don't think it's really needed, is it? At any rate, I've had no problems so far with it. PO may have installed the MSD prior to the Mallory; I had done the same. When I disconnected the MSD the motor ran just fine. Always keep a 605 module on hand. Two things I learned about the module: 1) Working in the engine compartment and causing a short around ignition components can blow the 605. 2) There is a situation where the module only partially fails-the engine cuts out, but seems to start again after a short wait. This is rare, but nice to know, and it has been documented. Lastly, the Mallory requires special spark plug wires. Great unit, best upgrade I ever added and well worth the money spent. |
stugray |
Oct 8 2015, 10:15 AM
I just happen to have:
Malloy unilite with optical module (from Tangerine racing) MSD 6AL digital (with rev limiter) Bosch Blue coil MSD Tach adapt. It runs very well And I log RPMs in my datalogger since the output of the Optical module is a nice clean 12VDC squarewave instead of a 400V noisy POS from a regular set of points. |
era vulgaris |
Oct 9 2015, 08:56 AM
PO may have installed the MSD prior to the Mallory; I had done the same. When I disconnected the MSD the motor ran just fine. Always keep a 605 module on hand. Two things I learned about the module: 1) Working in the engine compartment and causing a short around ignition components can blow the 605. 2) There is a situation where the module only partially fails-the engine cuts out, but seems to start again after a short wait. This is rare, but nice to know, and it has been documented. Lastly, the Mallory requires special spark plug wires. Great unit, best upgrade I ever added and well worth the money spent. It's possible, but the Mallory Unilite is on the engine build sheet from Original Customs, which was done right after he bought the car. The only thing I can guess is that he wanted the rev limiter that's on the MSD so he wouldn't damage his new engine. What's a 605 module? Does the MSD tach adapter keep the tach from being bouncy? My tach is fine while accelerating and upshifting. But a quick double clutch downshift will send it bouncing back and forth for a few seconds. |
Lo-Fi Version | Time is now: 24th April 2024 - 10:18 AM |
