Shift Rod Bushing (In tunnel by the firewall), 914-424-224-03 Very small play (Is this normal?) |
ndfrigi |
Oct 6 2015, 10:32 AM
Advanced Member Group: Members Posts: 2,928 Joined: 21-August 11 From: Orange County Member No.: 13,474 Region Association: Southern California |
Hi Teeners,
I got two separate order from two different vendors of the bushing because the 1st one I got seems to have a very small play when I test fit the bushing to the shift rod. So I was thinking the vendor sent me a wrong bushing. I order another one but now when I test fit it again to the shift rod, the same play I'm getting. Both bushing from two different vendor has the same part number 914-424-224-03 indicated on both plastic bag. It this the right shift rod bushing by the firewall? My shift rod diameter is very much straight. My old one that I removed has the same fitment or play with the new bushing. Thanks again! |
jimkelly |
Oct 6 2015, 06:17 PM
i think grinding usually means you have internal issues, like worn out syncro bands and at some point worn down dog teeth too. maybe anyway (IMG:style_emoticons/default/confused24.gif) good luck!
Lo-Fi Version | Time is now: 18th May 2024 - 09:06 AM |
