Intake Runner Connecting Hose |
stinkindiesel |
Oct 6 2015, 02:59 PM
Member Group: Members Posts: 184 Joined: 14-June 13 From: Georgetown, TX Member No.: 16,012 Region Association: Southwest Region |
I understand the intake runner hoses that seal the intake runners to the distributor housing on a 1.7L are no longer available. That's PN 022 133 241 B. What are people doing as a replacement? Just find some heater or radiator hose that fits tight over the tubes?
Gary |
Dave_Darling |
Oct 6 2015, 04:21 PM
914 Idiot Group: Members Posts: 14,985 Joined: 9-January 03 From: Silicon Valley / Kailua-Kona Member No.: 121 Region Association: Northern California |
I believe those are the wrong diameter. The "039" part number makes me think that those are for the 2.0 motor, which uses larger-diameter intake runner pipes than the 1.7 does. (The 1.8 uses the same size as the 2.0 ones.)
You'll have to clamp those down quite a ways to make them fit, I believe. See if you can find radiator hose of the correct diameter, that's probably a better option. --DD |
Lo-Fi Version | Time is now: 15th May 2024 - 06:01 AM |
