Mechanic help in DFW |
mr2by4 |
Oct 15 2015, 10:01 AM
Member Group: Members Posts: 182 Joined: 9-December 07 From: Fort Worth Member No.: 8,439 Region Association: Southwest Region |
Darn, I didn't knew about Zims swap meet, I'm in the Charlotte area on business. Let us know on the engine swap. I'm in Keller 817 715 3436 If you think that you could make it on Nov 21. That is the plan for the swap party. I may get my car together, but at the least its an excuse for a party! |
Cody914 |
Oct 15 2015, 06:46 PM
Newbie Group: Members Posts: 20 Joined: 21-July 12 From: Fort Worth, TX Member No.: 14,707 Region Association: Southwest Region |
If you have Clay going then you are in great hands and will probably get a whole lot more done than you would ever expect! I will try to make it out too and lend a hand as well. I think Clay could probably pull the engine blind folded, maybe we should test him and see... (IMG:style_emoticons/default/biggrin.gif)
mr2by4 |
Oct 15 2015, 07:35 PM
If you have Clay going then you are in great hands and will probably get a whole lot more done than you would ever expect! I will try to make it out too and lend a hand as well. I think Clay could probably pull the engine blind folded, maybe we should test him and see... (IMG:style_emoticons/default/biggrin.gif) Let's hope that my date works with Clay's schedule. If not, maybe I should reschedule! I will find out for sure this weekend at the swap meet. How late does that usually run? If I can't get by until after lunch is it a loss? I usually try to get there super early but this year I don't think that I can. |
Rob-O |
Oct 17 2015, 06:40 AM
Senior Member Group: Members Posts: 1,251 Joined: 5-December 03 From: Mansfield, TX Member No.: 1,419 Region Association: Southwest Region |
Let me check my schedule. Scratch that, let me check the kids schedules. I'll try to come out as well. I'm in Mansfield, so not too far. What all do you need part wise? Maybe I have some things on hand.
Rob-O |
Oct 17 2015, 07:19 PM
Well that was easy...I'm in.
ClayPerrine |
Oct 17 2015, 10:17 PM
Life's been good to me so far..... Group: Admin Posts: 15,429 Joined: 11-September 03 From: Hurst, TX. Member No.: 1,143 Region Association: NineFourteenerVille |
If you have Clay going then you are in great hands and will probably get a whole lot more done than you would ever expect! I will try to make it out too and lend a hand as well. I think Clay could probably pull the engine blind folded, maybe we should test him and see... (IMG:style_emoticons/default/biggrin.gif) Let's hope that my date works with Clay's schedule. If not, maybe I should reschedule! I will find out for sure this weekend at the swap meet. How late does that usually run? If I can't get by until after lunch is it a loss? I usually try to get there super early but this year I don't think that I can. Wow! Cody has a lot of faith in me........ I can't do it blindfolded, but I can certainly get it done quickly. If you want, we can make this a tech session on how to remove and reinstall a 914 motor. (IMG:style_emoticons/default/biggrin.gif) Anyone have a camera we can setup? If you have good bandwidth, we can live stream it so everyone on here can watch. |
Rob-O |
Oct 17 2015, 11:26 PM
I have a nice DSLR, but can't really stream with that.
Also, if you want to spend more time on the car and less in front of a grill, let me know. I can bring pizza (own a pizzeria here in Mansfield). After your car, in going to try this. My car looks great, needs work. It runs like total crap, 009 distributor, not timed correctly and has a crappy single barrel carb. Plus a ton of exhaust leaks and a (too loud for me) Sebring exhaust system. Not to mention I need to replace the clutch cable and replace the MC. But I'm in the same boat, no time!! |
Lo-Fi Version | Time is now: 2nd May 2024 - 12:17 PM |
