Front 911 Caliper/Sway Bar combo, Need some details on models/years |
3d914 |
Oct 6 2015, 08:15 PM
Senior Member Group: Members Posts: 1,275 Joined: 24-September 03 From: Benson, AZ Member No.: 1,191 Region Association: Southwest Region |
Planning to go 5-lug on the 914-SHO project and want to use the 911 suspension along with the calipers. In Eric's article on the topic he mentions S-Calipers, Turbo Calipers, A-Calipers and Wide A-Calipers (Carrera Calipers).
I'm not set on either caliper, but what I am set on is that I want the 911 suspension that includes the underbody Sway bar. Can someone outline the years and models (or point me to a source) that combines that sway bar with any of the above calipers? TIA |
bdstone914 |
Oct 6 2015, 09:27 PM
bdstone914 Group: Members Posts: 4,517 Joined: 8-November 03 From: Riverside CA Member No.: 1,319 |
Planning to go 5-lug on the 914-SHO project and want to use the 911 suspension along with the calipers. In Eric's article on the topic he mentions S-Calipers, Turbo Calipers, A-Calipers and Wide A-Calipers (Carrera Calipers). I'm not set on either caliper, but what I am set on is that I want the 911 suspension that includes the underbody Sway bar. Can someone outline the years and models (or point me to a source) that combines that sway bar with any of the above calipers? TIA I have sets of 911 A arms for the under body sway bar and several sway bars. You can use the A arms with and 911 (or 914 strut) You are best to stick with any strut 72 or later using the taper pin type ball joints. |
Lo-Fi Version | Time is now: 9th May 2024 - 03:10 PM |
