Outer wheel bearing issue. |
MikeM |
Oct 7 2015, 01:24 PM
Senior Member Group: Members Posts: 564 Joined: 16-May 10 From: Calgary, Canada Member No.: 11,733 Region Association: Canada |
Hi all...
How does the outer wheel bearing cage get distorted out of round? What kind of problem would that cause? Thanks, Mike |
screenguy914 |
Oct 7 2015, 03:40 PM
Member Group: Members Posts: 249 Joined: 6-July 09 From: So. Cal Member No.: 10,540 Region Association: Southern California |
Hi all... How does the outer wheel bearing cage get distorted out of round? What kind of problem would that cause? Thanks, Mike My educated guesses: - Overtightening the bearing preload - One or more ball bearings disintegrates causing cage to distort - Distorted race - Wheel collision with immovable object - Below standard bearing materials - Overheating of bearing assembly - Excessive play Possible results: - Bearing noise - Abnormal tire wear - Abnormal steering - Wheel seizure (lockup) - Spindle wear - death Sherwood |
Lo-Fi Version | Time is now: 10th May 2024 - 03:33 AM |
