Outer wheel bearing issue. |
MikeM |
Oct 7 2015, 01:24 PM
Senior Member Group: Members Posts: 564 Joined: 16-May 10 From: Calgary, Canada Member No.: 11,733 Region Association: Canada |
Hi all...
How does the outer wheel bearing cage get distorted out of round? What kind of problem would that cause? Thanks, Mike |
jcd914 |
Oct 9 2015, 01:04 AM
Advanced Member Group: Members Posts: 2,081 Joined: 7-February 08 From: Sacramento, CA Member No.: 8,684 Region Association: Northern California |
Usually the outer bearing cage gets distorted by someone using a screwdriver to move the bearing thrust washer to see if the preload is correct. They stick the screwdriver in too far and bend the cage trying to move the washer side to side.
Jim |
Lo-Fi Version | Time is now: 10th May 2024 - 08:16 AM |
