Outer wheel bearing issue. |
MikeM |
Oct 7 2015, 01:24 PM
Senior Member Group: Members Posts: 564 Joined: 16-May 10 From: Calgary, Canada Member No.: 11,733 Region Association: Canada |
Hi all...
How does the outer wheel bearing cage get distorted out of round? What kind of problem would that cause? Thanks, Mike |
jcd914 |
Oct 9 2015, 01:46 PM
Advanced Member Group: Members Posts: 2,081 Joined: 7-February 08 From: Sacramento, CA Member No.: 8,684 Region Association: Northern California |
The primary purpose of the cage is to hold the rollers in place when the bearing is out. If it is not badly bent you can straighten it. Just make sure it won't be rubbing either the inner or outer race.
Jim |
6freak |
Oct 12 2015, 12:10 PM
MR.C Group: Members Posts: 4,740 Joined: 19-March 08 From: Tacoma WA Member No.: 8,829 Region Association: Pacific Northwest |
The primary purpose of the cage is to hold the rollers in place when the bearing is out. If it is not badly bent you can straighten it. Just make sure it won't be rubbing either the inner or outer race. Jim Poor advice Mr Jim! the cage is for equal loading of the bearings and the races! nothing else, just install all new and then theres no worrys....the cheapest price is not always the best value! JMO good luck (IMG:style_emoticons/default/smile.gif) |
Lo-Fi Version | Time is now: 9th May 2024 - 10:54 PM |
