Thermostat cable and flaps |
hndyhrr |
Oct 7 2015, 01:28 PM
Senior Member Group: Members Posts: 554 Joined: 1-September 13 From: central point,oregon Member No.: 16,332 Region Association: Pacific Northwest |
I need to install a new thermostat xabke. Took the old one off and did not pat atten r ion to position of flaps. So fully closed is what the book says and that would be open on passenger side and closed on drive dide..........right?
JeffBowlsby |
Oct 7 2015, 02:04 PM
914 Wiring Harnesses Group: Members Posts: 8,484 Joined: 7-January 03 From: San Ramon CA Member No.: 104 Region Association: None |
Air-cooling flaps: Cold engine position (minimum airflow over oil cooler)
Attached image(s) |
era vulgaris |
Oct 7 2015, 02:32 PM
J is for Genius Group: Members Posts: 982 Joined: 10-November 13 From: Raleigh, NC Member No.: 16,629 Region Association: South East States |
The flaps should default to the open (warmed up) position when no cable is attached, because of the return spring.
The thermostat contracts when cold and pulls the flaps closed. |
Lo-Fi Version | Time is now: 28th April 2024 - 04:53 PM |
