How To Get The Letters Off The Engine Grill, Without busting the pins |
7TPorsh |
Oct 7 2015, 02:06 PM
7T Porsh Group: Members Posts: 2,691 Joined: 27-March 06 From: Glendale Ca Member No.: 5,782 Region Association: Southern California |
I have my stock grill which is a bit dated. It has the original gold Porsche letters that I wan to transfer to another grill. They are fastened pretty well.
Is there a way to get them off and still preserve the pins? without messing the grill up too bad? |
Cairo94507 |
Oct 7 2015, 02:12 PM
Michael Group: Members Posts: 9,722 Joined: 1-November 08 From: Auburn, CA Member No.: 9,712 Region Association: Northern California |
My recollection was those are held on with speed-nuts and that should unscrew off the pins.
bandjoey |
Oct 7 2015, 02:41 PM
bandjoey Group: Members Posts: 4,923 Joined: 26-September 07 From: Bedford Tx Member No.: 8,156 Region Association: Southwest Region |
Here's the original fastener. On the left. Hollow rubber with plastic teeth inside. Spray lube on the pins. Use a small plastic body tool. Y shaped. Gentle rocking and up will usually work. I'll post a pic of the teeth side tonight if you want.
Attached thumbnail(s) |
TheCabinetmaker |
I drive my car everyday Group: Members Posts: 8,300 Joined: 8-May 03 From: Tulsa, Ok. Member No.: 666 |
Actually, those nuts do not screw. They just push on and don't unscrew. I use a small screwdriver that has a crow's foot end. That's an end that looks like a small fork end of a crow bar. Just lift them off with no damage to letters.
matthepcat |
Oct 7 2015, 05:47 PM
Meat Popsicle Group: Members Posts: 1,462 Joined: 13-December 09 From: Saratoga CA Member No.: 11,125 Region Association: Northern California |
I just used tin snips to cut the speed nuts off.
wes |
Oct 7 2015, 06:21 PM
wes Group: Members Posts: 1,588 Joined: 8-December 07 From: Ukiah Ca Member No.: 8,436 Region Association: Northern California |
I soaked each pin in WD40 overnight and used a putty knife to lift while slightly twisting with a pliers and still broke one out of all the pins.
r_towle |
Oct 7 2015, 06:37 PM
Custom Member Group: Members Posts: 24,570 Joined: 9-January 03 From: Taxachusetts Member No.: 124 Region Association: North East States |
Tap pins out of nut with nail set
Lo-Fi Version | Time is now: 2nd May 2024 - 04:11 AM |
