BUILD-OFF CHALLENGE: MichiganMat |
MichiganMat |
Oct 7 2015, 02:41 PM
Member Group: Members Posts: 114 Joined: 14-June 06 From: San Jose, CA Member No.: 6,222 Region Association: Northern California |
Hey er'body, Im MichiganMat from San Jose and Im building a 914.
Backstory: This summer I had the pleasure of picking up a '75 914 chassis here in San Jose for a mere $300. It came with with virtually nothing: no driveline, no interior, no pedals, etc. Stripped, but solid, with minimal overhead and cost. I've been building 911s for many years now and had an extra set of wheels and 911 front struts in my shed, so I thought hey, lets do this. My brother and I are just finishing up putting an STi motor into our '67 912 too, so with that project wrapping up Im ready to jump into another. The Plan: Well, I got the car for cheap, and I've already got a perfectly good '75 911S to daily/rally/etc with, so the plan is to build a stripped down 914 racer for AX and track fun. The car will be getting: - Tangerine Racing rollcage, tied to 8pts, with nascar door-bars - Rennspeed fiberglass body (fenders f&r, hood, trunk, and both bumpers) - Mad Dog chassis reinforcement kit and hell-hole repair - Resto-Design floorpans, seat areas dropped by 2", with custom tunnel - Tilton pedals - 5 lug conversion - 16x7 Fuchs all the way around with 2nd option of 15x7ATE's with canti slicks - /likely/ wrx drivetrain, but Im exploring my options... Where sits today: I picked up the car in May and I've since then I've put it on a home-built rotisserie, cut the pans, tunnel, trunk, headlight buckets, and front fenders out of it, and fixed the hell-hole area. The pans were totally rotted, the battery tray was nonexistent, the fenders on all 4 corners had damage. Pretty easy to make the decision to start fresh, haha. Today, most of the chassis kit is installed but I can't finish it until the roll-cage is put in. Tangerine is almost done with the cage so it'll be another week or so until I see it. In the meantime, the plan is to clean up the wheel-wells, fix the rust in the longs, put in the trunk cross-sections, and primer the reinforcements. Then I'll get to work on the tunnel, mod'ing the pans, installing the fiberglass, etc. Anyways, hello, nice to meet you guys, and Im looking forward to the challenge! |
914forme |
Jan 27 2016, 06:33 AM
Unless you tie in the roof, you are only gusseting 18 ga sheet metal. You are basically re-enforcing the A-pilar. Worth anything, maybe in a crash, for stiffening on an open car, not really. Now if your going 916 style roof, I would say go for it. But DOM always wins over sheet metal. And depending on the class if you ever get the racing bug, they count as another point of attachment. For attachment points I try to make them as big as I can and cover at least 3 planes of contact. But again, people have rules, so you have to read them carefully. In NASA we get points per attachment point of the cage beyond 6 "older rules when I built the car" have not read this years yet. So if I was taking points I would make sure it had a valid result. Also if I was gusseting a bar into the chassis it would be the cross bar at the front. And I would take the dash out, run it to the front fire wall and gusset it across the entire wall. That gets it away from your knees and adds a huge amount of chassis tie in. I also added a bar across the back behind my seat that went down picked up the center seatbelt points and back across. Any time you can make a complete hoop, and not rely on the chassis the better off you are. Next I would concentrate on the tie into the suspension points.
? how much of a street car do you want this to be (IMG:style_emoticons/default/huh.gif) |
Lo-Fi Version | Time is now: 5th May 2024 - 10:58 AM |
