BUILD-OFF CHALLENGE: MichiganMat |
MichiganMat |
Oct 7 2015, 02:41 PM
Member Group: Members Posts: 114 Joined: 14-June 06 From: San Jose, CA Member No.: 6,222 Region Association: Northern California |
Hey er'body, Im MichiganMat from San Jose and Im building a 914.
Backstory: This summer I had the pleasure of picking up a '75 914 chassis here in San Jose for a mere $300. It came with with virtually nothing: no driveline, no interior, no pedals, etc. Stripped, but solid, with minimal overhead and cost. I've been building 911s for many years now and had an extra set of wheels and 911 front struts in my shed, so I thought hey, lets do this. My brother and I are just finishing up putting an STi motor into our '67 912 too, so with that project wrapping up Im ready to jump into another. The Plan: Well, I got the car for cheap, and I've already got a perfectly good '75 911S to daily/rally/etc with, so the plan is to build a stripped down 914 racer for AX and track fun. The car will be getting: - Tangerine Racing rollcage, tied to 8pts, with nascar door-bars - Rennspeed fiberglass body (fenders f&r, hood, trunk, and both bumpers) - Mad Dog chassis reinforcement kit and hell-hole repair - Resto-Design floorpans, seat areas dropped by 2", with custom tunnel - Tilton pedals - 5 lug conversion - 16x7 Fuchs all the way around with 2nd option of 15x7ATE's with canti slicks - /likely/ wrx drivetrain, but Im exploring my options... Where sits today: I picked up the car in May and I've since then I've put it on a home-built rotisserie, cut the pans, tunnel, trunk, headlight buckets, and front fenders out of it, and fixed the hell-hole area. The pans were totally rotted, the battery tray was nonexistent, the fenders on all 4 corners had damage. Pretty easy to make the decision to start fresh, haha. Today, most of the chassis kit is installed but I can't finish it until the roll-cage is put in. Tangerine is almost done with the cage so it'll be another week or so until I see it. In the meantime, the plan is to clean up the wheel-wells, fix the rust in the longs, put in the trunk cross-sections, and primer the reinforcements. Then I'll get to work on the tunnel, mod'ing the pans, installing the fiberglass, etc. Anyways, hello, nice to meet you guys, and Im looking forward to the challenge! |
MichiganMat |
Jan 31 2016, 10:32 PM
Today I worked on dropping the drivers floor pan down by 1 inch. Cut along the outside of the pan, made a few bends in the metal brake, and welded a 1" strip of 16ga around the perimeter. The goal is to get the driver seat nice and low, Im 6'1", need to get my helmet away from the top of the roof and below the roll cage. I've seen this done on a few of the Patrick Motorsports builds, seems like a well-known mod. I still need to figure out how to mount the seat brackets to the pan and decide if I'll use sliders or not. A few questions left to be answered...
I also started thinking about how to build the custom tunnel / shifter console. I have a few ideas but Im going to need more steel and welding gas. I'll likely start in on it next weekend after gathering parts. Its tough to fit anything without the seat mounted in :/ I need to pick up used shifter (seems like people are using Toyota MR2, I wonder if there are other options?) and a pedal cluster (thinking Tilton or Wilwood at the moment). |
Lo-Fi Version | Time is now: 5th May 2024 - 08:20 AM |
