BUILD-OFF CHALLENGE: MichiganMat |
MichiganMat |
Oct 7 2015, 02:41 PM
Member Group: Members Posts: 114 Joined: 14-June 06 From: San Jose, CA Member No.: 6,222 Region Association: Northern California |
Hey er'body, Im MichiganMat from San Jose and Im building a 914.
Backstory: This summer I had the pleasure of picking up a '75 914 chassis here in San Jose for a mere $300. It came with with virtually nothing: no driveline, no interior, no pedals, etc. Stripped, but solid, with minimal overhead and cost. I've been building 911s for many years now and had an extra set of wheels and 911 front struts in my shed, so I thought hey, lets do this. My brother and I are just finishing up putting an STi motor into our '67 912 too, so with that project wrapping up Im ready to jump into another. The Plan: Well, I got the car for cheap, and I've already got a perfectly good '75 911S to daily/rally/etc with, so the plan is to build a stripped down 914 racer for AX and track fun. The car will be getting: - Tangerine Racing rollcage, tied to 8pts, with nascar door-bars - Rennspeed fiberglass body (fenders f&r, hood, trunk, and both bumpers) - Mad Dog chassis reinforcement kit and hell-hole repair - Resto-Design floorpans, seat areas dropped by 2", with custom tunnel - Tilton pedals - 5 lug conversion - 16x7 Fuchs all the way around with 2nd option of 15x7ATE's with canti slicks - /likely/ wrx drivetrain, but Im exploring my options... Where sits today: I picked up the car in May and I've since then I've put it on a home-built rotisserie, cut the pans, tunnel, trunk, headlight buckets, and front fenders out of it, and fixed the hell-hole area. The pans were totally rotted, the battery tray was nonexistent, the fenders on all 4 corners had damage. Pretty easy to make the decision to start fresh, haha. Today, most of the chassis kit is installed but I can't finish it until the roll-cage is put in. Tangerine is almost done with the cage so it'll be another week or so until I see it. In the meantime, the plan is to clean up the wheel-wells, fix the rust in the longs, put in the trunk cross-sections, and primer the reinforcements. Then I'll get to work on the tunnel, mod'ing the pans, installing the fiberglass, etc. Anyways, hello, nice to meet you guys, and Im looking forward to the challenge! |
MichiganMat |
Feb 29 2016, 11:34 AM
Nice progress (IMG:style_emoticons/default/beer.gif) Radiator the current darling of 914 world seems to be the Ebay Toyata Celica GT with shroud and fans, I think t is ~$150 I being different and having to cut my own path IE the harder way went Griffen and now get to build everything. For the pedals I went Wilwood and used Titon M/Cs 5/8" for clutch, 3/4" for the brakes. I am currently running 1988 911 Calipers. They are heavy SOBs so I will most likely go Wildwood there also. Here is the point to that above, the Tilton M/C are pretty short, almost as short as the Howe racing, more sizes. Not sure how tall you are, but you loose at least 2" if you keep everything inside the cabin. If you redo the pedal wall, you run into items on suspension tie in. Trying to figure my way around this one. The Tilton's also exit out the back, the howe's are angle up. Other items of note, don't forget about your Intercooler. Most here have hound they get heat soaked when sitting still. And most go for Air to Water Intercoolers. That means two extra lines going forward. Another Rad up front, and a pump and box. But it is the best way to go. You can also do an ice box if you wanted to, for that extra bit of cooling. Keep up the great work here! Thank you, its been an interesting journey so far. Its fun that we're all building together, loving the progress from the other threads. Radiator: thats great info, thank you, i'll check them out. Pedals: Also, great to know. I am really kind of concerned about pedal travel / feel and total size of the cluster. I haven't pulled the trigger on anything yet, but any advice on it would be welcomed. Im 6 feet tall and would prefer to not lose any space in the cabin. Cutting out the pedal wall would not be my first choice either. Tilton (I think) makes a cluster where the masters effectively sit under the heels of your feet, so those may be an option, but I know nothing about the feel of the travel on those things. Intercool: {sigh}. Yeah. On our 912-STi build we tucked a huge intercooler under the ducktail and put a full-time fan on it which worked pretty well, but there are plenty of disadvantages. Not sure what I'll do yet, need to do more research. Are air-to-water ICs as efficient as air-only ICs? Thanks a bunch - Mat |
Lo-Fi Version | Time is now: 5th May 2024 - 01:23 PM |
