BUILD-OFF CHALLENGE: MichiganMat |
MichiganMat |
Oct 7 2015, 02:41 PM
Member Group: Members Posts: 114 Joined: 14-June 06 From: San Jose, CA Member No.: 6,222 Region Association: Northern California |
Hey er'body, Im MichiganMat from San Jose and Im building a 914.
Backstory: This summer I had the pleasure of picking up a '75 914 chassis here in San Jose for a mere $300. It came with with virtually nothing: no driveline, no interior, no pedals, etc. Stripped, but solid, with minimal overhead and cost. I've been building 911s for many years now and had an extra set of wheels and 911 front struts in my shed, so I thought hey, lets do this. My brother and I are just finishing up putting an STi motor into our '67 912 too, so with that project wrapping up Im ready to jump into another. The Plan: Well, I got the car for cheap, and I've already got a perfectly good '75 911S to daily/rally/etc with, so the plan is to build a stripped down 914 racer for AX and track fun. The car will be getting: - Tangerine Racing rollcage, tied to 8pts, with nascar door-bars - Rennspeed fiberglass body (fenders f&r, hood, trunk, and both bumpers) - Mad Dog chassis reinforcement kit and hell-hole repair - Resto-Design floorpans, seat areas dropped by 2", with custom tunnel - Tilton pedals - 5 lug conversion - 16x7 Fuchs all the way around with 2nd option of 15x7ATE's with canti slicks - /likely/ wrx drivetrain, but Im exploring my options... Where sits today: I picked up the car in May and I've since then I've put it on a home-built rotisserie, cut the pans, tunnel, trunk, headlight buckets, and front fenders out of it, and fixed the hell-hole area. The pans were totally rotted, the battery tray was nonexistent, the fenders on all 4 corners had damage. Pretty easy to make the decision to start fresh, haha. Today, most of the chassis kit is installed but I can't finish it until the roll-cage is put in. Tangerine is almost done with the cage so it'll be another week or so until I see it. In the meantime, the plan is to clean up the wheel-wells, fix the rust in the longs, put in the trunk cross-sections, and primer the reinforcements. Then I'll get to work on the tunnel, mod'ing the pans, installing the fiberglass, etc. Anyways, hello, nice to meet you guys, and Im looking forward to the challenge! |
MichiganMat |
Jun 2 2016, 05:16 PM
I know its been a bit of radio-silence on my end, but I've been busy!
So what have I been up to: - pulled the wheel bearings out of the trailing arms, bought new bearings - discovered one of my front a-arms was bent, sourced new arms on eBay for cheap - bought new front turn signal lenses - bought dash gauge panel - researched and bought rear brake calipers - sourced a powder-coating shop, going to take all the suspension pieces in for coating - converted my subaru trans to 2wd (found some ugly bits in there, turned out be harmless) - installed my through-hood gas cap Its been a busy couple of weeks, no? I need to take more pictures! Every time I do one of these updates I realize how few pics I have to show, heh. Generic gas filler from some internet site: Installed. Separated the neck from the ring, welded in. Took off the bottom of the bowl and welded around the perimeter. Need to add a drain, but that ain't no biggie. Not a lot of room to work with in there! Not a bad look, no? Bits of ground up center-diff c-clip. Had me worried! Turned out to be just fine. Tail panel bolted up after the conversion So making good progress I think. The next steps are: - Take the suspension bits off to the powder-coater - Strip down the gas tank and paint it - Buy a pedal cluster, fab into the floorpan, then the pans can go in permanently - Then take the chassis off to the blasting shop, strip and prime Easy peasy, right? |
Lo-Fi Version | Time is now: 5th May 2024 - 10:13 AM |
