BUILD-OFF CHALLENGE: MichiganMat |
MichiganMat |
Oct 7 2015, 02:41 PM
Member Group: Members Posts: 114 Joined: 14-June 06 From: San Jose, CA Member No.: 6,222 Region Association: Northern California |
Hey er'body, Im MichiganMat from San Jose and Im building a 914.
Backstory: This summer I had the pleasure of picking up a '75 914 chassis here in San Jose for a mere $300. It came with with virtually nothing: no driveline, no interior, no pedals, etc. Stripped, but solid, with minimal overhead and cost. I've been building 911s for many years now and had an extra set of wheels and 911 front struts in my shed, so I thought hey, lets do this. My brother and I are just finishing up putting an STi motor into our '67 912 too, so with that project wrapping up Im ready to jump into another. The Plan: Well, I got the car for cheap, and I've already got a perfectly good '75 911S to daily/rally/etc with, so the plan is to build a stripped down 914 racer for AX and track fun. The car will be getting: - Tangerine Racing rollcage, tied to 8pts, with nascar door-bars - Rennspeed fiberglass body (fenders f&r, hood, trunk, and both bumpers) - Mad Dog chassis reinforcement kit and hell-hole repair - Resto-Design floorpans, seat areas dropped by 2", with custom tunnel - Tilton pedals - 5 lug conversion - 16x7 Fuchs all the way around with 2nd option of 15x7ATE's with canti slicks - /likely/ wrx drivetrain, but Im exploring my options... Where sits today: I picked up the car in May and I've since then I've put it on a home-built rotisserie, cut the pans, tunnel, trunk, headlight buckets, and front fenders out of it, and fixed the hell-hole area. The pans were totally rotted, the battery tray was nonexistent, the fenders on all 4 corners had damage. Pretty easy to make the decision to start fresh, haha. Today, most of the chassis kit is installed but I can't finish it until the roll-cage is put in. Tangerine is almost done with the cage so it'll be another week or so until I see it. In the meantime, the plan is to clean up the wheel-wells, fix the rust in the longs, put in the trunk cross-sections, and primer the reinforcements. Then I'll get to work on the tunnel, mod'ing the pans, installing the fiberglass, etc. Anyways, hello, nice to meet you guys, and Im looking forward to the challenge! |
Andyrew |
Nov 26 2018, 09:00 AM
Spooling.... Please wait Group: Members Posts: 13,376 Joined: 20-January 03 From: Riverbank, Ca Member No.: 172 Region Association: Northern California |
Your setup sounds exactly like mine and your experience at the track sounds like mine as well! My car had slow turn in response as well as a tendancy for what felt like understeer but it never lost front grip. The rear on the other hand would spin the inside tire on any throttle adjustment mid/late corner. We were probably similar for power as my boost was on the wastegate and my confidence level in the car was extremely low.
I've been thinking that the fix is to finish up my nascar front sway bar as well as see about some more toe/camber/sticky rubber. |
MichiganMat |
Nov 26 2018, 03:45 PM
Your setup sounds exactly like mine and your experience at the track sounds like mine as well! My car had slow turn in response as well as a tendancy for what felt like understeer but it never lost front grip. The rear on the other hand would spin the inside tire on any throttle adjustment mid/late corner. We were probably similar for power as my boost was on the wastegate and my confidence level in the car was extremely low. I've been thinking that the fix is to finish up my nascar front sway bar as well as see about some more toe/camber/sticky rubber. Im going to throw some $ at it and get the front Tarett bar, it made a huge difference in the handing of my 911 so Im truly hoping for a dramatic change in the character of this 914. Its... undrivable in its current form. The hyper-aggressive turn-in, coupled with a tail that has no grip is just too much to wrangle on a racetrack. If you get there before me, let me know what find, Im curious. |
Lo-Fi Version | Time is now: 5th May 2024 - 03:02 AM |
