Source For Taco Plate O-Ring Needed |
Ansbacher |
Oct 7 2015, 07:10 PM
Senior Member Group: Members Posts: 689 Joined: 4-July 14 From: Tampa Bay, Florida Member No.: 17,589 |
So, who the heck carries the red O-ring to seal the taco plate? Need to change out my oil temp sensor and don't want to put an old o-ring back in. Pic of what I need below -
Ansbacher |
914Sixer |
Oct 7 2015, 07:14 PM
914 Guru Group: Members Posts: 8,844 Joined: 17-January 05 From: San Angelo Texas Member No.: 3,457 Region Association: Southwest Region |
Let me look, I may have a new one.
Ansbacher |
Oct 7 2015, 08:42 PM
That would be cool.
era vulgaris |
Oct 7 2015, 09:02 PM
J is for Genius Group: Members Posts: 980 Joined: 10-November 13 From: Raleigh, NC Member No.: 16,629 Region Association: South East States |
Pelican Parts, man! Looks like they have 1 left in stock.
http://www.pelicanparts.com/catalog/SuperC..._pg4.htm#item16 |
stugray |
Oct 7 2015, 09:39 PM
you can also change the temp sensor without removing the lower (or upper I guess) plate
but "while youre in there...." Youll need the two small crush washers (Item 51 N-013-803-2 sealing ring C6 X 10) that go on the two bolts. |
Mikey914 |
Oct 7 2015, 10:06 PM
The rubber man Group: Members Posts: 12,622 Joined: 27-December 04 From: Hillsboro, OR Member No.: 3,348 Region Association: None |
Crusty sent me some washers I'll check to see what I've got.
He sold me the last of what he had in stock last time he did them. |
Ansbacher |
Oct 8 2015, 09:47 AM
Thanks everyone for your help and generosity. I have ordered everything from Pelican (and yes, that was the last o-ring in stock there!).
Ansbacher |
7TPorsh |
Oct 8 2015, 11:05 AM
I need one too. Getting ready to put together the assembly and mount.
Will this work or both seal and gasket are needed for the taco mounting? |
luskesq |
Oct 8 2015, 12:09 PM
Member Group: Members Posts: 276 Joined: 24-October 10 From: Fresno, CA Member No.: 12,303 Region Association: Central California |
You need both.
Keith |
914Sixer |
Oct 8 2015, 03:41 PM
021 101 269A. Elring 762.024 is another part number. Outer diameter is 85mm,Inner diameter is 77mm and 4mm thickness. The material is MVQ Silicone Elastomer.
Lo-Fi Version | Time is now: 28th March 2024 - 04:07 PM |
