dcecc1968 |
Member ![]() ![]() Group: Members Posts: 255 Joined: 31-December 12 From: Concord, NC Member No.: 15,313 Region Association: South East States ![]() |
I'm installing a set of dual webers and I noticed that the inlet fuel line will connect towards the rear on one of the carbs and towards the front on the other carb. I'm sure it'll work fine like this but I'm a little OCD about this.
Can the hose barb fitting shown below be reversed to the other side as shown by the yellow arrow? Or is this not advisable? I don't want to have to buy a rebuild kit to get another gasket to enable me to do this. Thanks, Don ![]() |
Harpo |
Senior Member ![]() ![]() ![]() Group: Members Posts: 1,304 Joined: 21-August 11 From: Motor City aka Detroit Member No.: 13,469 Region Association: None ![]() |
Yes, if you can get the nut out.
Custom Member ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() Group: Members Posts: 24,705 Joined: 9-January 03 From: Taxachusetts Member No.: 124 Region Association: North East States ![]() ![]() |
Yes, they are made to do that
stugray |
Advanced Member ![]() ![]() ![]() ![]() Group: Members Posts: 3,825 Joined: 17-September 09 From: Longmont, CO Member No.: 10,819 Region Association: None ![]() |
You got lucky. The castings I have seen have ports on both sides, but only one is drilled & tapped.
You can drill & tap the other side, but its a delicate op for DIY with handtools. The dellortos have a banjo type of fitting that you can flip over to point either way. |
Lo-Fi Version | Time is now: 13th July 2025 - 10:27 AM |
