SS Fuel Lines (Tangerine) Install, Does it matter? |
sdoolin |
Oct 11 2015, 11:22 AM
Member Group: Members Posts: 357 Joined: 1-May 14 From: LouKY Member No.: 17,299 Region Association: None |
Have OE flexible lines removed. Engine still in car, gas tank out.
Does it matter which fuel line goes where? They all have slightly different bends so I would guess that it matters at least a little bit. I mean I know that the long ones go through the tunnel and the short ones into the engine compartment (duh), but not sure otherwise. My kit from Tangerine did not have instructions, so looking for any help. |
sdoolin |
Oct 11 2015, 02:37 PM
Thanks for all the replies, long lines are installed, buffered (wrapped with spare fuel hose in a couple of places) and clamped down.
On to the engine compartment... I took it apart long enough ago that I don't recall which side is the feed and which is the return. The injectors on drivers' side get the "feed" first, then back across to the passenger side, then return to tank? If I had a pump mounting bracket I think I'd be driving it tonight... |
Lo-Fi Version | Time is now: 18th April 2024 - 05:59 PM |
