SS Fuel Lines (Tangerine) Install, Does it matter? |
sdoolin |
Oct 11 2015, 11:22 AM
Member Group: Members Posts: 357 Joined: 1-May 14 From: LouKY Member No.: 17,299 Region Association: None |
Have OE flexible lines removed. Engine still in car, gas tank out.
Does it matter which fuel line goes where? They all have slightly different bends so I would guess that it matters at least a little bit. I mean I know that the long ones go through the tunnel and the short ones into the engine compartment (duh), but not sure otherwise. My kit from Tangerine did not have instructions, so looking for any help. |
mepstein |
Sep 15 2020, 05:21 PM
914-6 GT in waiting Group: Members Posts: 19,221 Joined: 19-September 09 From: Landenberg, PA/Wilmington, DE Member No.: 10,825 Region Association: MidAtlantic Region |
The tabs hold down the oem plastic line. I don’t think I used them for the stainless line. It helps to have a spotter. Makes it a 5 minute job. Lube the ss lines so they slip through the rubber grommets easily.
The gas tank does have to come out. |
andrewck |
Sep 15 2020, 05:24 PM
Newbie Group: Members Posts: 48 Joined: 5-July 20 From: Denver Member No.: 24,461 Region Association: Rocky Mountains |
The tabs hold down the oem plastic line. I don’t think I used them for the stainless line. It helps to have a spotter. Makes it a 5 minute job. Lube the ss lines so they slip through the rubber grommets easily. The gas tank does have to come out. Appreciate it! Everything (including gas tank) are out of the car, so hoping for easy installation. |
Lo-Fi Version | Time is now: 19th April 2024 - 12:12 PM |
