headlights power question |
jimkelly |
Oct 16 2015, 01:02 PM
my car is without a relay box and my fuse panel may be a little jacked up, so I will be replacing it. I am checking my lights using a battery charger which seems to be putting out about 9.2 volts.
I've pulled my headlight motors cause i will be running my car with lights UP all the time. when I pull my headlight switch out, I get tail lights, front amber and front side amber, but no head lights. I was wondering if the power to the headlight motors in part of the ciurcuit to make the head lights function? when I pull my emergency light switch, I hear a buzz in its flasher, maybe its flasher is no good. i turned ignition key and did see my wipers work, but real slow, i'm guessing 9 volts is not quite cutting it. yeah, i am missing a few fuses, got a big pack on oprder from an ebay seller. Attached image(s) |
jimkelly |
Oct 16 2015, 01:22 PM
I think you are answering my question, seems I need to do something with the loose wires that were previously connected to the headlight motors. thanks.
oh, and yes, I have been puling switch out all the way, just double checked that is was. so I need to figure out which wires on the headlight tri plug needs power, and where they get power from for low beams and for high beams. clearly I had no idea the motors acted like switches too (IMG:style_emoticons/default/dry.gif) Attached image(s) |
Lo-Fi Version | Time is now: 18th May 2024 - 07:52 PM |
