| Trekkor |
Mar 7 2005, 10:11 PM
I do things... ![]() ![]() ![]() ![]() ![]() Group: Members Posts: 7,809 Joined: 2-December 03 From: Napa, Ca Member No.: 1,413 Region Association: Northern California |
I'd like to polish these to a mirrorlike finish.
How much time does it take per wheel to do it right and what should I pay to send them out? What is the best process? fine grit wet paper all the way down to #0000 steel wool and then Mother's polish? Thanks. KT Attached image(s)
| Gint |
Mar 8 2005, 08:51 AM
Mike Ginter ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() Group: Admin Posts: 16,108 Joined: 26-December 02 From: Denver CO. Member No.: 20 Region Association: Rocky Mountains |
The small tips don't hold up to the real harsh cutting compunds. They fall apart. I tried the heavy cutting compounds and they suck. I found sanding to perform much better overall. I also polished the edges of all of the holes. Most polishers won't do that detail. Because that's the part that has to be done by hand. With the proper heavy duty machinery, this can be quick work to do the faces.
That why my last set went to Al. You didn't read all of what I said. I would definitely pay top have them done now after that one experience. I only did that one wheel. Too much work. But that experience taught me the value of Al's work. And it took 30 hours because I had to figure out a process. I could do that now in under 20 (IMG:http://www.914world.com/bbs2/html/emoticons/wink.gif) |
trekkor wheel polishing 101 Mar 7 2005, 10:11 PM
Unclerichy The bird board has a good tech article on wheel po... Mar 7 2005, 10:13 PM
914forme NO Steel wool - it will imbed in the aluminum and ... Mar 7 2005, 10:19 PM
trekkor I have these Pedrini's that someone nicely pol... Mar 7 2005, 10:53 PM
Gint There's a lot of labor in that wheel Trekkor. ... Mar 7 2005, 11:14 PM
Gint 'nother. Mar 7 2005, 11:15 PM
Gint Glass bead blast (which I wouldn't do if I did... Mar 7 2005, 11:17 PM
Rand Dang Gint, that's beautiful. Mar 8 2005, 04:10 AM
redshift http://www.914world.com/bbs2/htm... Mar 8 2005, 04:24 AM
Gint http://www.914world.com/bbs2... Mar 8 2005, 12:37 PM
vsg914 Here's mine after hand polishing with a high t... Mar 8 2005, 12:37 PM
Travis Neff That looks sweet Curt, that satin finish is nice... Mar 8 2005, 01:40 PM![]() ![]() |
Lo-Fi Version | Time is now: 9th August 2026 - 08:27 PM |
