F/S Misc new rubber stuff |
Harpo |
Oct 17 2015, 12:37 PM
Senior Member Group: Members Posts: 1,304 Joined: 21-August 11 From: Motor City aka Detroit Member No.: 13,469 Region Association: None |
I have the following left over from my build
New targa sail vinyl - $12.00 + S/H New side marker lens seal (2) - $6.00 + S/H New door handle gasket - $3.00 + S/H New outer door window seal/scraper - $4.00 + S/H New front trunk plugs (9) - $16.00 + S/H New eyebrow grommets (6) $3.00 + S/H New tuna can - $30.00 + S/H - Pending to Mark New F/G rocker panels - $100 + S/H |
euro911 |
Oct 17 2015, 04:38 PM
Gloy62 |
Oct 17 2015, 06:48 PM
Newbie Group: Members Posts: 5 Joined: 6-November 14 From: Poway Member No.: 18,096 Region Association: None |
New door handle gasket - $3.00 + S/H New outer door window seal/scraper - $4.00 + S/H New front trunk plugs (9) - $16.00 + S/H New eyebrow grommets (6) $3.00 + S/H I will take these items New tuna can - $30.00 + S/H What is this? Greg |
jacksun |
Oct 18 2015, 02:20 AM
Member Group: Members Posts: 236 Joined: 8-August 13 From: mi Member No.: 16,224 Region Association: Upper MidWest |
third in line for
New targa sail vinyl - $12.00 + S/H (if complete set) New side marker lens seal (2) - $6.00 + S/H (if both sides) New door handle gasket - $3.00 + S/H (if both sides) New outer door window seal/scraper - $4.00 + S/H (if both sides) New eyebrow grommets (6) $3.00 + S/H thanks randal |
Harpo |
Oct 18 2015, 12:18 PM
Sail panel vinyl & tuna can are pending to euro
New door handle gasket, New outer door window seal/scraper, New front trunk plugs, New eyebrow grommets are pending to Glory I will give these guys 24 hrs to coordinate payment before moving to the next in line. David |
euro911 |
Oct 18 2015, 12:49 PM
Sail panel vinyl & tuna can are pending to euro David, I just replied to your PM a few ago (late riser) (IMG:style_emoticons/default/yellowsleep[1].gif) New door handle gasket, New outer door window seal/scraper, New front trunk plugs, New eyebrow grommets are pending to Glory I will give these guys 24 hrs to coordinate payment before moving to the next in line. David I'm going to pass on the vinyl, but I do want to purchase the tuna can ... |
jacksun |
Oct 20 2015, 06:33 AM
would the 24 be up?
tks randal |
Harpo |
Oct 20 2015, 03:46 PM
Yes, the 24 hrs are up and the misc rubber stuff is yours. I will send you a PM
jacksun |
Oct 21 2015, 03:49 AM
pm sent
tks randal |
Lo-Fi Version | Time is now: 13th May 2024 - 12:59 PM |
