Driveway Paintjob Thread, I will update up to the WCC |
skline |
Mar 8 2005, 12:35 AM
Born to Drive Group: Members Posts: 7,910 Joined: 26-December 02 From: Costa Mesa, CA Member No.: 17 Region Association: Southern California |
This will be my step by step driveway strip and paint thread. This may not be the way everyone will do it, but this is the way I will do mine. If you like it, you can do it this way also. If not, then you can take it to a body shop and pay $3k to $5k for a paint job. You could also do different variations and run the cost up. I will post what I spend on this entire process. Some have said its like hitting your self in the head with a hammer, ok, this will be my first smack in the head.
First shot, before. Attached thumbnail(s) |
skline |
Mar 9 2005, 08:37 AM
Actually, the stripper only needs to set for about 10 to 15 minutes depending on how strong it is. You can actually hear the paint seperating from the car one coat at a time. It will most likely take 2 or 3 applications to get the bulk of it off. If you leave it on too long, it will dry and wont scrape off as easy. Only do one section at a time as it will dry before you get to the other side. The most I have done at one time is a door and a fender or a hood and fender and that was pushing it. Once you start with the chemicals, you need to go all the way to metal. There will still be some sanding when you get done with the stripper.
Lo-Fi Version | Time is now: 15th May 2024 - 02:47 PM |
