WTB : New/NOS right Longitudinal side member, Part # : 914 501 436 12 |
Luke M |
Oct 21 2015, 08:14 AM
Senior Member Group: Members Posts: 1,369 Joined: 8-February 05 From: WNY Member No.: 3,574 Region Association: North East States |
...No Longer need one... Part # : 914 501 436 12 , right Longitudinal Side member. Thanks, Attached image(s) |
OU8AVW |
Oct 22 2015, 09:03 AM
Yacht Rigger Group: Members Posts: 1,803 Joined: 1-October 08 From: Granbury, TX Member No.: 9,601 Region Association: Southwest Region |
914work |
Oct 22 2015, 10:25 AM
Member Group: Members Posts: 291 Joined: 9-November 11 Member No.: 13,762 Region Association: None |
I count 6 different repop pieces.
The motor mount isnt reproduced yet. |
Luke M |
Oct 22 2015, 01:01 PM
I've called RD before I posted this ad and we spoke about this part. The problem is that when you buy the replacement panel it's missing the outer shell which is not in production. I would need to fab that part myself or outsource it. I do not need the 4 cyl mount as this is going in to my factory 6.
I did get a few leads that I'll be checking into. |
Oct 22 2015, 01:15 PM
I thought I saw it on eBay for a touch under $3k. I searched - Porsche 914 nos
Luke M |
Oct 22 2015, 01:24 PM
stevegm |
Advanced Member Group: Members Posts: 2,111 Joined: 14-July 14 From: North Carolina Member No.: 17,633 Region Association: South East States |
IIRC the "outer shell" is called the inner rocker panel. RD makes it. Part number P301R for the passenger side.
Never mind I see that you need the piece in the engine compartment. |
cary |
Oct 22 2015, 10:40 PM
Luke is right. The RD piece isn't an exact replacement for the factory piece.
The factory piece is two layers. The corrugated portion is on the inside. Outside is smooth. The RD piece is 16 gauge I believe. With the portion inside the engine compartment corrugated. Here's what Nathan did ............... http://www.914world.com/bbs2/index.php?sho...3507&st=160 I do believe both sides are available from Porsche Classic. Big Bucks ... |
cary |
Oct 22 2015, 10:49 PM
Luke M |
Oct 23 2015, 06:42 AM
Luke is right. The RD piece isn't an exact replacement for the factory piece. The factory piece is two layers. The corrugated portion is on the inside. Outside is smooth. The RD piece is 16 gauge I believe. With the portion inside the engine compartment corrugated. Here's what Nathan did ............... http://www.914world.com/bbs2/index.php?sho...3507&st=160 I do believe both sides are available from Porsche Classic. Big Bucks ... That's the problem that I'm having and why I'm looking for a factory part. It's going in my 914-6 and if possible I would like to use a factory part for the repair. I did order the RD part and it should be here any day now. I'm going to see how it all fits first. I did call Stoddard but they only have the drivers side with the pass side being NLA. I called a few other places but no one has it in the US. Also checked stock in Germany, nothing. Someone out there may have it stashed away but good luck finding it. I'm sure one will turn up after I get it fixed and no longer need it. So for now it's plan B and see how that works. |
stevegm |
Oct 23 2015, 07:45 AM
Luke is right. The RD piece isn't an exact replacement for the factory piece. The factory piece is two layers. The corrugated portion is on the inside. Outside is smooth. The RD piece is 16 gauge I believe. With the portion inside the engine compartment corrugated. Here's what Nathan did ............... http://www.914world.com/bbs2/index.php?sho...3507&st=160 I do believe both sides are available from Porsche Classic. Big Bucks ... That's the problem that I'm having and why I'm looking for a factory part. It's going in my 914-6 and if possible I would like to use a factory part for the repair. I did order the RD part and it should be here any day now. I'm going to see how it all fits first. I did call Stoddard but they only have the drivers side with the pass side being NLA. I called a few other places but no one has it in the US. Also checked stock in Germany, nothing. Someone out there may have it stashed away but good luck finding it. I'm sure one will turn up after I get it fixed and no longer need it. So for now it's plan B and see how that works. I hope you find one. In fact, I hope you find two. I need that exact piece also. I found the driver's side piece earlier this year. But I haven't found the passenger one. |
cary |
Oct 24 2015, 06:49 AM
Luke, how far into the long do you need to go?
cary |
Oct 24 2015, 08:00 AM
Here's the RD piece after mounts are installed. The biggest issue I see with skinning the RD piece is getting water trapped behind it.
I did install a gusset cover down by the firewall. But I left the top and bottom open for drainage. |
Luke M |
Oct 24 2015, 09:27 AM
Luke, how far into the long do you need to go? I would need to go all the way forward as the inner long is rough. I figured just replace it all vs piece meal. So from the rear engine/truck wall forward to the inner fender. Just like the picture shows. I believe that's the only way the factory sold it. I did find someone with one of these but it's not for sale. I did get the RD parts so looks like I'm going that route. Attached image(s) |
cary |
Oct 24 2015, 10:03 AM
You checked with Arno and Mittelmotors in Europe?
914fahrer |
Oct 24 2015, 02:19 PM
Member Group: Members Posts: 103 Joined: 12-November 14 From: Berlin/Germany Member No.: 18,115 Region Association: Germany |
Hello , They have a lot off Nos Part`s http://www.914neuteile.de/cms/front_content.php?idcat=58 Gruss Ralf |
Luke M |
Nov 29 2015, 08:28 AM
(IMG:style_emoticons/default/icon_bump.gif) for the heck of it...
The more I think about it I want to stick with the factory metal. Has anyone ever dealt with these guys? http://www.914neuteile.de/cms/front_content.php?idcat=58 |
Luke M |
Feb 5 2016, 11:15 AM
bernbomb |
Feb 5 2016, 11:39 AM
Newbie Group: Members Posts: 1 Joined: 28-January 16 From: Temecula ca 92591 Member No.: 19,608 Region Association: Southern California |
74 914 roller with very little rust in so cal might be worth your while to ship?
around $ 800.00 |
Luke M |
Mar 19 2016, 03:53 PM
(IMG:style_emoticons/default/icon_bump.gif) before Hershey....
Still looking for the part circled in red. Attached image(s) |
Lo-Fi Version | Time is now: 26th April 2024 - 09:44 AM |
