Just another Factory 6 being fixed up |
Luke M |
Oct 23 2015, 12:26 PM
Senior Member Group: Members Posts: 1,371 Joined: 8-February 05 From: WNY Member No.: 3,574 Region Association: North East States |
Well it's gotten to be that time finally. I've been collecting parts to do the repair on my 914-6 and now the work starts. The main issue is the hell hole/inner engine long, inner pass long, pass inner rocker panels are rusted out. The last part I was trying to source seams to be NLA. I sourced most of the parts from the good guys at Restoration Design. I received my order today for the last batch of things. Based on a few threads that I've looked over the outer shell to the inner engine long is currently not being made by RD. A few guys have made their own which looks like a real pain in the rear to do. I laid out all the new metal to see how things lined up. By the looks of things it will need some fine tuning to mate things properly. Before I start cutting into the chassis I'll build a few braces to keep things true.
Time for the pics... Attached image(s) |
Luke M |
Jul 16 2018, 11:33 AM
Started to check the door gaps and adjusting them. I can't seam to close the front door gap at all. Must be the new to the car doors as my old set seamed to fit better.
I currently have the pass door at 3 mm at the top with 4 mm towards the middle. The front half is 6 mm top to 7 mm on down. I checked my drivers side and have 3 mm at the top, 4 mm towards the bottom. At the front of the drivers side I have 5 mm at the top and 6 mm towards the bottom. Anyone have any idea what the door gaps should be set at ? Need to figure this out before I move to the next step.. (IMG:style_emoticons/default/sawzall-smiley.gif) Attached image(s) |
Lo-Fi Version | Time is now: 14th May 2024 - 08:00 AM |
