Just another Factory 6 being fixed up |
Luke M |
Oct 23 2015, 12:26 PM
Senior Member Group: Members Posts: 1,371 Joined: 8-February 05 From: WNY Member No.: 3,574 Region Association: North East States |
Well it's gotten to be that time finally. I've been collecting parts to do the repair on my 914-6 and now the work starts. The main issue is the hell hole/inner engine long, inner pass long, pass inner rocker panels are rusted out. The last part I was trying to source seams to be NLA. I sourced most of the parts from the good guys at Restoration Design. I received my order today for the last batch of things. Based on a few threads that I've looked over the outer shell to the inner engine long is currently not being made by RD. A few guys have made their own which looks like a real pain in the rear to do. I laid out all the new metal to see how things lined up. By the looks of things it will need some fine tuning to mate things properly. Before I start cutting into the chassis I'll build a few braces to keep things true.
Time for the pics... Attached image(s) |
mb911 |
Jul 16 2018, 03:23 PM
914 Guru Group: Members Posts: 6,850 Joined: 2-January 09 From: Burlington wi Member No.: 9,892 Region Association: Upper MidWest |
I will have to tackle this shortly. I am not sure what it should be but I have never seen a 914 with consistent gaps..
Superhawk996 |
Nov 24 2019, 09:46 AM
914 Guru Group: Members Posts: 5,815 Joined: 25-August 18 From: Woods of N. Idaho Member No.: 22,428 Region Association: Galt's Gulch |
I will have to tackle this shortly. I am not sure what it should be but I have never seen a 914 with consistent gaps.. (IMG:style_emoticons/default/agree.gif) @Luke M @MB911 5-6mm gaps (and inconsitent) were not at all uncommon in any 1970's era cars domestic or imported. I could write a dissertation on how body dies used to be cut in the Pre-CNC era. Basically, it was done by a Keller Tracing Mill that basically carved metal by tracing a cutting path on a 3-D master which was usually a Kirksite (Zinc based alloy that cuts sort of like Aluminum) prototype die that would only be suitable for low volume use. As the path was traced on the Kirksite die, a production die was simultaneously being cut out of cast iron. Think of a pantograph but cutting cast iron instead of tracing a drawing on paper. Needless to say, accuracy wasn't what it is today. Don't kill yourself trying to get a consistent 3-4 mm gap that you would expect today. It isn't going to happen without welding door edges. |
Lo-Fi Version | Time is now: 14th May 2024 - 02:18 PM |
